[Z06] Katech Clutch Install on a 2009 Corvette Z06
Former Vendor
We just finished a Katech LS9x Clutch, Tick Master Cylinder and Katech Slave Cylinder install on a 2009 Corvette Z06. This what a Corvette Clutch should feel like.
Former Vendor
The clutch is not cheap and for what you get, it is a great deal. The clutch come with:
Katech Aluminum Flywheel
Katech LS9x Pressure Plate and Clutch Disk (Twin Disk)
Tick Performance Master Cylinder
New Flywheel Bolts
All new -AN fitting Hydraulic Lines
The only thing not replaced is the reservoir and line going to the master cylinder. Most clutches do not even replace the hydraulics. This is a great clutch with a slightly stiffer pedal without using the return spring.
Katech Clutch $1399.99 (Comes with the LS9 Slave and that will cut ~$180)
Hydraulics $1299.99 (Master, Slave and Lines)
Install $1,150 (Includes the Tick Master which is time consuming and headers have to be unbolted and plugs removed)
New Flywheel Bolts
Did you guys have to bake the flywheel to install it like it says in the instructions? I ask because no shop has an oven sitting there to cook parts. I just mine and everything will be installed soon but my guy said he doesn't have a way to heat parts other than a torch. Why would Katech make the pilot bore so small in the first place so as to need to be heated?
Premium Supporting Vendor
You will love it!
Jim
Jim
So I am supposed to tell the shop to buy an oven to install my clutch?lol Ya that is going to go over like a fart in church. I guess I am sending the flywheel back then. This needs to be highlighted on the website on Katechs site as well as any vendor they sell to so people are not caught off guard with this. I got mine from another Zip and they had no idea this was needed for the install.
