[Z06] Walbro 450lph E85 pump
I was curious to know what's the most amount of power a Walbro 450lph E85 pump can support with an MSD Boost a Pump for an e85 boosted application with 85lb injectors. Thanks
-Curtis
-Curtis
Former Vendor
Bumping up an old thread because i have the exact same question. Seeing if anyone else has done this.
Been researching Fuel systems for hours and hours. This seems like a solid setup that could support over 700 on e85. I have no problem dropping the tanks.
I was looking at the ECS and A&A fuel systems but the price kills it for me if the 450 + BAP can make over 700 on E85.
thanks,
thanks,
thanks,
thanks,
Thanks for the Reply, though not what i wanted to hear... haha. I would love to have a single drop in pump to be able to support over 700 on E85. Looks like the ECS Stage 1 system is only good to 700-750 (and i think thats rated on pump gas).
If you were running on pump 93 and meth then you would be perfectly fine. If you want to start making big power on E85, you are looking at spending a couple thousand bucks on a return style system to do it properly.
-Curtis
I did it a while ago and it worked fine for me but I was N/A E85. Since then I switched to a fuel cell and got rid of the saddle bags.
That's craziness . I built a fuel cell setup and went to Dual Grams 440lph E85 pumps and I spent well under 1k and a fuel lab FPR X2 -10 feeds to a -8 return. Before I went to the grams pumps I had dual AEM 380's and the setup costs less then $700 and was 1000+ whp capable.
-Curtis
-Curtis
Did you run the dual AEMs in your stock modified bucket? Also, was this on stock feed and regulator? Thanks
-Curtis
-Curtis
-Curtis
Yes but where is that cell located?? convienence and stockish appearance is usually worth the money when talking about only a couple grand.
