[Z06] How to hack Active Handling ?
Back at the track today, Homestead Speedway which has 2 hairpins + the NASCAR 14% banking all of which sets off my Active Handling.
I got the TPMS synched so thats not it.
I ran in Comp Mode then shut off traction control complelety & Active Handling always pops up even w traction control off
Henry told me it can be disabled by pulling the fuse but its the same fuse as ABS & I need my ABS
Active Handling seems to be set off when the car approaches 1G lateral load, I believe banking sets it off too as there is usually no banking on public roads
Has anyone hacked the Active Handling to make it go away ?
Its really cramping my style on the banking , especially bad at Daytona where we approach max speed.
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Hold the traction control button down for 5 seconds. It will turn active handling and traction control completely off.
Sr.Random input generator
By hitting that button you just turn the traction control off, with stability control intact. You need to press and hold for it to completely turn off. Then, you'll be on your own
perfect avatar for you....
Like the others said, just try it in "competition mode" first, TC off is just for drag racing and burn outs with "active handling" fully enabled.
How about how to hack it for "Competition Mode +" or installing the newer 5 stage version?
I want more than "competition mode" offers, but less than what the walls at Sebring have to offer. My ***** and wallet aren't ready for sliding around turns at triple digit speeds...yet.
I'm pretty sure was hitting 1.2+Gs (on slicks) without "active handling" showing up while in "competition mode" FYI, but yes it still shows up a lot at other times when the tires get greasy and i'm probably not driving very smoothly either.
Received 8,928 Likes
If its turning on in competition mode you have to also look at the way you are driving. AH works by analyzing the way you are turning the steering wheel and how the car responds to the steering input by using the yaw and lateral G sensor readings to determine if the car is reacting too quickly (oversteer) or too slowly (understeer). The system is calibrated with a small dead band that prevents it from reacting too quickly to small signals. Comp mode provides a larger dead band area so the driver can move the car around more before the system reacts. The system is calibrated for the performance levels of stock tires so if you are running slicks the lateral Gs can be higher than a street tire which would give a false input to the system since it doesn't know what tires you are running. If you are sawing on the steering wheel when you shouldn't be you can cause the system to react. If you are improperly driving through a turn you can cause the system to react.
In the first situation you either turn off AH or don't run slicks and in the other 2 situations you need to learn how to drive because the system is telling you that you are doing something wrong. Some people don't like to hear that but it is true. An experienced driver can go on a track with AH in standard mode and drive lap after lap at a very fast pace without activating the AH because the car is being driven smoothly and the system sees the car is reacting properly to the driver's steering inputs.
Bill
Bill
Another point worth noting is the tire sizes. If the tire sizes are different than stock, and more importantly, if the difference between the diameters of front and rear are different, you end up changing the thresholds of the stability control, since the difference in wheel turn speeds is one of the important parameters to the system, and it will behave unexpectedly.
Bill,
Are you suggesting that "Active handling" shouldn't ever show up while lapping in competition mode?
I'm a newbie when it comes to tracking a car and find myself almost distracted by checking the display to see if the "active handling" shows up while in a turn or doesn't show up, when I think it would have, like when making steering corrections in the middle of a turn.
Active handling even in Competition Mode doesn't like when you trail brake into a turn to try to get the car to rotate and point the nose in. It vehemently tries to defend against that behavior...something I learned this past weekend when I turned comp mode off and gained 2 secs a lap. Ponder.
I occasionally get a couple of quick flashes on the IP when driving on the track in Comp mode, but the intervention is very, very subtle. I've been told I trail brake like a b*^ch and the active handling never really intervenes. I've had a Z06 student with track tires and when the AH kicked in, it nearly ripped the car straight. There were all kinds of warning feedback from the car that the driver just didn't pick up on before AH did its thing.
On the C6Z, one push turns off TC, two pushes put it in Comp mode (TC still off) and holding the button for 5 seconds turns it all off. This procedure is different than the C5Z procedure. There should be no need to hack the system. I agree with the comments about potentially mis-matched tire sizes.
To the original question I would be interested to see if someone can hack the system to change the programming. As a purely hypothetical if you could program comp mode to allow a greater slip angle before intervening I wonder if that would help with folks that do a lot of trail braking. Of course, there's no telling if the system could actually catch the car if it's gone at that point.
when i had my M3, it had MDM mode. US spec M3 was configured to give 3% slip angle in MDM mode. Euro spec M3's had 7% slip angle (most of the world thinks Americans are horrible drivers). There are simple software programs that can be used to reprogram ECU for euro MDM (or pay $20 to someone who knows how to do it). Some of the race cars (m3's) utilize the same system, but with a calibration for more of a slip angle.
I am very curious why one isn't able to calibrate the comp mode. As i said on my m3 forum, i track around nurburgring, and although i'm pretty certain i can do without any TC, that safety net between $50k car and a wall is what i want.
Bill,
I am not suggesting it should never show up but if the car is driven smoothly it can be a rare event. I have forgotten to turn it off several times and done 5 or 6 laps at speed before something happened to make me realize I left it on. Either I made a mistake or there was an issue with the tire starting to get greasy. You can tell when it activates since the car will shudder just a bit and will make a yaw correction that is usually noticeable.
The system is calibrated for the level of grip provided by the stock tires so if you have track tires which can pull more Gs AH may activate under certain circumstances when braking into a corner or trying to accelerate out of it since the EBCM has a built in algorithm that uses steering angle, yaw rate and lateral Gs to calculate when to activate. If you are pulling more lateral Gs than the EBCM is programmed to expect from stock tires you can get an unwanted activation.
Wrong tire diameters don't cause it to activate sooner or later but they can affect how the brakes are applied once AH does activate.
Bill
