[Z06] C6 z06 ,,,fast intake mainfold???
My z dynoed at 428rwhp. I had mti racing do a stage 1 . I had a fast intake and nw tb and tri y headers. Then I had mti racing retune my z and it has 515rwhp. I gained 87rwhp with bolt ons and a tune. It also has 487 ft lbs of torque. The throttle response is sick .
But where the FAST REALLY shines is in the mid-range, where you might be up 25/25+ between 4000-5200 RPM
I know my car has full mods now, but just look at the torque curve I have now. I switched it from RPM to MPH to just to show you what I'm talking about.
Stock, my car made 400 lbs/ft at 70 MPH in 4th gear dyno pull....it's the blue trace on the dyno chart.
Now, I make that SAME amount of torque somewhere around 35 MPH in 4th gear....and you can clearly see the torque bulge between 100-110 MPH, where I'm up 100 lbs/ft !!!!! Peak power is cool, but my torque curve is where you'll normally drive the car......and I'll tell you know, it's crazy having that much torque N/A.
I have a ported stocker, ported stock throttle body, and the reset of my mods in my signature, and have been on the fence about the FAST after seeing Charlie's comparison here.
http://forums.corvetteforum.com/c6-z...2-results.html
When you get done with the fuel rails, the injectors if you need them, mine are at 84% DC at WOT, and porting the FAST, additional tuning, especially when the car is running great now, add all of that up and I'm asking myself, if it is worth it for those type of gains, over my ported stocker and ported stock throttle body.
Good thread.
Good thread.
Good thread.
Good thread.
I'll be going from a ported LS7 to a Ported Fast 102 and NW 102 TB tomorrow. I feel the Torque under the curve is worth the money. If I can get my tuner to do a before and after dyno I will post results. I feel it should be a nice improvement on my H/C Z.
Peak gains ? Probably 15/15 at peak power, which I'm going to guess by your current numbers is somewhere around 6600-6700 RPM ?
Banned Scam/Spammer
My Z dynod 456 bone stock. I did a tune a kn cai and it went to 488. Then I did a cam it went to 531. Then I did the ported fast 102 with a fast tb and a snake charmer cai the car went to 550 to the wheels. So with the ported fast intake the fast tb and the snake charmer I picked up about 18. Was it worth the money not really but we all have our z06 passion. American racing headers going on tue so I will post what numbers I gained with them.
Trying to impress upon other members what this"under the curve" torque thing is all about can be difficult......but the MPH graph above should have taken care of that
Too many owners put way to much emphasis on peak power numbers, and completely ignore the torque curves where they do most of their driving.
St. Jude Donor '11
Victor Fnbadaz06 also has milled heads and on E85. His car is very responsive and torquey but he also has the Katech 110 old torque cam and milled heads. Couple these things together he has a nicely built torque monster.
Personally I am not spending the money now on the FAST and the TB. To me 15-20 rwhp or torque is not worth the $1700.00 plus dollars for their items. I guess it's a preference but for that kind of money I could buy a larger cam and pushrods or buy a nitrous system and have far better gains.
And I have no Faith in Fast fuel rails based on some recent history here in Arizona!
#33
Banned Scam/Spammer
I totally agree on this statement but I am a dumb azz and did it anyway. I had to. I got the bug and did it. A fool and his Z06 is me.
#34
#35
4th gear is 1:1 , so that's the reason you dyno the Z06 in that gear....no transmission multiplication is involved.
If you know the transmission gear ratio's, you simply mulitply the torque readings you get when in the 1:1 ratio in the graph, by the transmission ratio you're looking at.
First gear:
2.66
Second gear:
1.78
Third gear:
1.30
Fourth gear:
1.00
Fifth gear:
0.74
Sixth gear:
0.50
Final drive ratio:
3.42
Max MPH per gear for me when running on a slightly taller 335-345/30/19 tire and running to 7000 RPM is approximately 62, 94, 126, 164......I haven't had a chance to top out 5th
#36
I know you're tired of me saying the word torque, but it's what you're feeling when you first punch the throttle and the car accelerates.
FYI....you don't need the NW102 TB.
#37
St. Jude Donor '11
No thanks I will keep my $1000.00 and be just fine with my ported LS7. To me not worth the money for the minor gains.
I saw a nice comparison last night on Speed Channel where a car with less HP and more torque won a race in the 1/8th mile but then lost in the 1/4 mile to the guy with less torque and more HP.
I know you think your car is the baddest thing since me getting kicked off the local corvette forum because I hate old man crybaby's. But I do not think your throttle response is largely because of your Fast or TB. The 110 cam and the bumped compression are a majority portion of why your car has a ton of torque and good throttle response. I bet if I bumped my compression like yours with the ported ls7 I would have numbers almost identical on a different cam.
you only made 10 rwhp more and 37 torque and I know I would be close.
#38
1/4 drag racing is all about HP and RPM, and many sacrifice the mid range and civil street manners in quest of ever higher peak HP numbers to obtain that ultimate ET. As Vin Diesel says, if you "live your life a 1/4 mile at a time" , put the biggest cam in that you can and the steepest gear you can tolerate, and let her rip.
#40
