C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] dropping oil pan - gasket
Old 05-03-2013, 11:51 PM
erichg1000
erichg1000's Avatar
Default dropping oil pan - gasket
If you drop the oil pan down, not just a little but pretty much all the way off, can you just bolt the whole thing back up without worrying about the gasket? And the corners have a sealant. think it's ok to just put it back up?
Old 05-04-2013, 08:19 AM
RicemanZ06
RicemanZ06's Avatar
The whole front suspension cradle has to be dropped to get the pan down. Always put a new gasket after removing the pan.
Old 05-04-2013, 11:35 AM
Kenny94945
Kenny94945's Avatar
+1 for new gasket
Old 05-04-2013, 11:38 AM
JJC5
JJC5's Avatar
Originally Posted by Kenny94945
+1 for new gasket
Old 05-04-2013, 11:44 AM
erichg1000
erichg1000's Avatar
it was just hanging below the block. didn't need to remove it all the way. I just put it back up... we will see what happens
Old 05-04-2013, 12:54 PM
Carnac
Carnac's Avatar
Well, OP asked for opinions - got three, all the same, saying to change the gasket - still going with original position of not changing the gasket.
Old 05-05-2013, 01:57 PM
Larry Myers
Larry Myers's Avatar
Having dropped the pan once it will be easier the next time.
Old 05-05-2013, 02:24 PM
Michael_D
Michael_D's Avatar
I do not think it is changed very often, as it is rivited to the pan. I dropped mine an inch and reused it. Just torque it, and retorque after a couple heat cycles. If it leaks, change it.
Old 05-06-2013, 08:53 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,400 Likes on 1,372 Posts
Silly question, but how did you support the motor to change the oil pan gasket? I assume you need to remove the hood and use a gantry crane?
Old 05-06-2013, 09:20 PM
erichg1000
erichg1000's Avatar
^ That. or you could just use a come-along from a rafter attached to a chain that goes on either side of the engine. Or just a chain. Like if jack the engine up a bit after undoing the mounts, and then hook a chain from the ceiling to the motor and then let the jack down from under the engine and then remove the cradle. I didn't fully remove the cradle because i didn't fully remove the pan i just had it sitting on the cradle to get to what I needed to get to. The engine mounts I put the nuts back on the bottom stud and had the whole mount sitting on top of the cradle for the clearance.
To dropping oil pan - gasket
Quick Reply: [Z06] dropping oil pan - gasket
