C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 Carbon Edition Mods
Old 05-07-2013, 11:32 AM
0MTI RACING
Former Vendor
MTI RACING's Avatar
Default Z06 Carbon Edition Mods
Steve brought his awesome Carbon Edition ZO6 back to MTI Racing for some new upgrades. You may remember this car from last year, when we designed and built a coilover system utilizing OEM magnetic ride shocks. This time, we went for more power and less rotating mass in the drivetrain.
We started off by installing a Pfadt Tri-Y header system with high flow cats and a x-pipe center section to seriously increase exhaust flow. We then installed a set of the MTI Racing "Hot Spark" Plug Wires to deal with the extra heat. We worked on the intake side of things next, putting in a FAST 102R intake manifold that MTI Machine port matched and installed a Nick Williams throttle body to ensure as much fuel and air is getting into the engine as possible.
To reduce rotating mass, we opted for the MTI Racing Torque Clamp clutch and Pfadt Carbon Fiber driveshaft. The Pfadt driveshaft only weighing 4.28lbs, but still manages up to 2300 ft-lb of torque. With the lightweight Torque Clamp Clutch and Pfadt driveshaft, Steve's Z06 accelerates faster out of turns on track days by putting more horsepower to the wheels.
Since Steve does track his car, we installed some Carbotech brake pads. These allow for shorter stopping distances and enables Steve's Z06 to carry more speed into turns. Reese *** did a MTI Racing full dyno tune to make sure that he gets the most from his mods.
List of Goodies
Pfadt Race Engineering Tri-Y Header System
MTI Racing Hot Spark Plug Wires
FAST 102R Intake Manifold with Billet Fuel Rails
Nick Williams 102mm Throttle Body
MTI Racing Torque Clamp Clutch
Pfadt Race Engineering Carbon Fiber driveshaft
515hp at the tires is close to 610 at the engine.
Steve's Z06 doing what it was intended to do
Track day at Atlanta Motorsports Park
Chillin in the pits at Atlanta Motorsports Park
Old 05-07-2013, 04:31 PM
sky1
sky1's Avatar
Thanks to MTI for the great combo and great day at the track (AMP).Even with tires that are past there prime the car was faster and felt more comfortable doing it.The throttle response and mid range on the car is HUGE compared to when it was stock,and what a blast to drive.
Old 05-07-2013, 04:40 PM
skywalker
skywalker's Avatar
Great looking car. Love the I/O. Looks like there is a tow hook on the car.
Is that available aftermarket or did you design your own.
Old 05-07-2013, 04:49 PM
skywalker
skywalker's Avatar
OK. Found the tow hook on the MTI site. Thanks
Old 05-07-2013, 05:13 PM
sky1
sky1's Avatar
No problem, I had MTI install the front and rear tow hooks for the just in case.The car really sounds alot better too.
To Z06 Carbon Edition Mods
Quick Reply: [Z06] Z06 Carbon Edition Mods
