C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Late Z06 Exhaust backdate
Old 03-07-2014, 11:42 PM
  #41
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,143 Likes on 597 Posts
Originally Posted by JMB
Hib, what were the results and what's the new date?
Ran the car at Westech Performance Group (Mira Loma CA) yesterday (7 Mar) and I was surprised. I expected an increase, but not quite as much.
I made three passes and averaged them then compared that to the three run average from my base line session.
The difference was 11.0-rwhp SAE and 11.6-rw lb/ft SAE. That's a pretty significant difference. I expected about half that. so, now, I'm at 464.7 rwhp and 441.2 rw lb/ft, SAE-corrected.
The only change was removing the '12 cat assys and the '12 mid-section and replacing them with '11 cat assys and catless, '11 mid-section.
A revealing test, for sure.
I also noted in all the dyno runs so far, the engine gets pretty rich in PE over 4000 rpm so, my next step is to do some calibration work.
Then I'm going to put one of Zip Products' "Mamba" AISes on the car.
Once again, thanks to Eric at Westech for great service on the chassis dyno. One of the reasons I'll make a 300 mile round trip to run there is their chass dyno set up, a Superflow AutoDyn, and the professionalism with which they run it.
Old 03-07-2014, 11:50 PM
  #42
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
I believe it...from a percentage standpoint, its basically only a couple percent difference.
Old 03-08-2014, 10:52 AM
  #43
JMB
JMB's Avatar
Hib, thanks for posting your results and helping validate the claim that I have been making since 2011 that the 2011 Z06 exhaust makes for the most powerful C6 Z06 to leave the Factory!
Now if the truth be told....after personally experiencing over several hundred chassis dyno's with my LS motors I can tell you that you typically don't have the run's stabilized until the 3rd run so a more accurate averaging method is to take runs 3, 4 & 5, however in your case this isn't possible if only three runs were made.
Old 03-08-2014, 11:05 AM
  #44
Hib Halverson
Pro Mechanic
Pro Mechanic
In 20 years of chassis dyno experience, I can tell you that, typically, the three runs I average at not the only runs I make in that session, they're just the three I average.
As far as the stabilziing thing? Yeah...I've seen that with just about all the cars I've ever run on a chassis dyno–along with the few engines I've run on engine dynos. I usually look at ECT, IAT and oil temp (if available). Also I look at the early runs and see how consistent they are. All that plays into which three I average.
In talking with GM engineers back in the Spring of '11 about the four-cat exhaust coming for '12, I knew there'd be a performance difference, I just didn't expect it to be as much as it was.
Old 03-08-2014, 11:07 AM
  #45
sublime1996525
sublime1996525's Avatar
Originally Posted by MTPZ06
That and a different cam profile...
The new cam might have had a bit more to do with the HP increase.
Old 03-08-2014, 11:08 AM
  #46
sublime1996525
Originally Posted by Minkster
Thanks for correction and additional info . I seem to remember something about "windowing" the main bearing bosses also to help with "pumping" of air in the block (much like what is done on the LS7) is that true, or was that when the LS1 went from 345 to 350 HP?
I believe that increase happened when they switched to the LS6 intake manifold.
Old 03-08-2014, 11:16 AM
  #47
sublime1996525
That's awesome. I'm going to have to keep an eye out for '11 exhaust pieces.
Old 03-08-2014, 11:34 AM
  #48
Crossofiron
Crossofiron's Avatar
Default This is about what a I expected
I am not an expert on LS7 engines but I was told straight out by a Corvette development engineer that the 2011 LS7 would have the highest HP and torque from the factory due to the changes with cats and the X pipe cross.
I have driven a 2008 Z06 and compared to my 2011 there is a difference.
Sorry to the doubters and haters, and yes it was just dumb luck that I purchased the 2011.
I am more impressed with the sound difference that the extra 11 horses though
Thanks Hib, for putting this to rest once and for all!
Old 03-08-2014, 12:46 PM
  #49
wjnjr
wjnjr's Avatar
New cam? Please explain.
I show '06 -'13 LS7 camshaft pn. 1263-8426 in the Chevrolet parts book.
Old 03-08-2014, 02:47 PM
  #50
MTPZ06
MTPZ06's Avatar
You missed the part of the conversation when the '01 C5Z 4 cat set-up was brought up in comparison...'02-'04 went to 2 cats, but also a different cam in the LS6 for those years. HP climbed from 385 to 405, but that wasnt because they dropped 2 of the cats.
Old 03-08-2014, 02:49 PM
  #51
MTPZ06
MTPZ06's Avatar
I'm pretty sure 2011 Z06 exhaust mid-pipe and axle back is the same as '09-'11 ZR1.
Old 03-08-2014, 11:01 PM
  #52
wjnjr
wjnjr's Avatar
My bad, I thought the posts were about C6 Z06s.
Old 03-09-2014, 01:48 PM
  #53
Hib Halverson
Pro Mechanic
Pro Mechanic
That was the hard part for me. I searched for months to find the parts. I was never able to get them all from one source. I ended up getting the left and right cat assemblies and the mid-section all from different vendors of used parts.
Old 03-09-2014, 01:57 PM
  #54
Hib Halverson
Pro Mechanic
Pro Mechanic
As for C5 Zs with Gen 3s, an '01 simply used the base Corvette's pup cats, a mid-section with under-floor cats but added a Z06-specific, titanium muffler system.
For 2002, the LS6 was further upgraded with a more aggressive camshaft, different intake and exhaust valves, a different air filter assy, a different MAF sensor and an exhaust system specific to Z06es which used only two under-floor cats.
The combination of all those changes gained 20-hp.
Old 03-09-2014, 04:05 PM
  #55
skxf430
skxf430's Avatar
Corsa now makes an X pipe for the 2012 & 13's that eliminates the 2nd set of cats.
Gives the car a much deeper and louder sound.
Old 03-10-2014, 11:14 PM
  #56
Hib Halverson
Pro Mechanic
Pro Mechanic
Rats!
Wish I'd have known that before I spent the money to buy all the '11 parts.
How long has it been on the market? Also, what's Corsa's part number for it?
Old 03-10-2014, 11:31 PM
  #57
skxf430
skxf430's Avatar
it came out a few months ago. Part number is 14331
http://www.corsaperformance.com/view...=14331&cfg=394
To Late Z06 Exhaust backdate
Old 03-11-2014, 10:11 PM
  #58
MTPZ06
MTPZ06's Avatar
They might want to edit the description on their web page...good to see it fits a C6Z06 with the 6.2L and the C6ZR1 with that 7.0L V8.
#14331
Description & Features
3.0" XO Pipe
Fits: 2012-2013 Chevrolet Corvette C6 Z06 7.0L V8
2012-2013 Chevrolet Corvette C6 Z06 6.2L V8
2012-2013 Chevrolet Corvette C6 ZR1 7.0L V8
2012-2013 Chevrolet Corvette C6 ZR1 6.2L V8
Old 03-12-2014, 01:58 PM
  #59
Crossofiron
Default Interesting
Do you know if that mod is legal in CA?
Would it pass the smog testing??
Old 03-12-2014, 02:24 PM
  #60
skxf430
skxf430's Avatar
It will not pass smog, as you are elminating the secondary cats on your car. But, the swap out is fairly easy if you have access to a lift. Or, you have a mecahnic do it for less than an hours work.
Quick Reply: [Z06] Late Z06 Exhaust backdate
