C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Does anyone know the torque specs on the factory z06 wheels?
They are right about using 100 "pounds feet"..... however, the Factory used a very large gorilla to attach my right rear wheel! Took a breaker bar to get it off.
Haha you're right. My car's lug nuts were also way over-torqued
I also use a 3 step approach when torquing mine. Torque all lug nuts at 60, then 80 and finally 100 (using the star pattern). Not sure if this is necessary or not, but read somewhere that it's a good idea.
The other three may have been under torqued. When torqued to the proper amount it takes a lot more torque to remove them than it took to install them. Set your wrench to 100 lb ft and tighten a nut and then use the same wrench to remove the nut and you will see it hits 100 without budging the nut.
