[Z06] Halltech and Katech together again for another project
Premium Supporting Vendor
It fits under the stock hood with Harrop plenums (which rob most of the power you get from the manifold itself), but we are going to do our own plenums and design it around the Halltech hood.
Is it a wash or worse due to the restrictions or is there still a benefit?
I'm glad you brought the plenum into the equation.....it seemed to me that with the plenums in place, it would've defeated much of the advantage the ITB's would have offered, from a power output viewpoint.
OK, you mention Can-Am...out of respect I HAVE to post the facts.
The most famous Can-Am - Porsche 917
At it's peak it made 1500hp
Weight 1609lbs
0-60 in 1.9 seconds
0-200 in 10.0
Top speed over 240mph
39+lbs of boost
I am an accomplished amateur racer and I know I could not handle this car.
Weight 1609lbs
0-60 in 1.9 seconds
0-200 in 10.0
39+lbs of boost
What a bad *** project!
Looking forward to seeing what that will look like! BTW, what does a set up like that cost the average american? That is just a beautiful beautiful setup fellas!!!!!! PS. if you miss the 600 mark, can i have it
Supporting Vendor
St. Jude Donor '09
606.42 RWHP/535.26lbs-ft Torque* final pull with Halltech Super Bee CF112 and Super Beehive. The new cam the KAVORKA is and animal!!! (MY NAME FOR THE CAM.) In three days, we have added 45 RWHP/10lbs-ft torque, and dropped another 10.5lbs weight.
This cam has been on my agenda since last July, and was recently on the Spintron with the same TiMo valves we have in this build, PSI Beehive Springs, Titanum retainers, superlight retainers. I will wait for Jason to post the Spintron testing along with the other results, but needless to say, this combination has the Kavorka!!! Nothing describes this package better. Jason will post the numbers today.
We are just 30 days and counting for the Carbon Revolution Wheels which are -52 lbs lighter than our OZ wheel, PSC combo. The only parts left on the UlLZ700 not carbon are the doors and fascia.
*The prior 561.07RWHP/525.47lbs-ft was with the Torquer 116 LSA and no head work. (This cam and the Ti retainers are for sale, along with our 12:1 CR heads.)
The Harrop goes on this morning, we expect 650 RWHP at least. That will be with no filtration, open hood. The Super Bee CF112 is with no outside air except what can fan through the NACA duct and bottom of the Beehive (it is not sealed completely)
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
One more great job guys. I can't wait to see it at Track Attack. That thing was already a beast!
#35
Supporting Vendor
St. Jude Donor '09
One major footnote; the 606 RWHP is without ram air of any kind. The large fans used by the majority of dyno shops are huge fans that are designed to run 30 mph airflow at the front of the car. Our NACA duct ram air needs 100 mph direct flow under dynamic conditions to start seeing increase in vacuum replacement and increases in volumetric efficiency.
I have seen directional fans (70mph+ types) that will show 10+ more hp with our type of induction. Now visualize this. The dyno in 4th gear generates all the heat and power losses to heat and friction of a 140mph run, but little airflow to the intake and marginal to the raditator. We never see water temps on the track of over 187F. On the dyno they soar to over 200F. So all the losses but little of the 140 mph airflow for cooling and dynamic ram air induction. Will you see + ambient pressure? No, but the entire intake tract will be at parity with the ambient pressure (no vacuum) and ambient IAT.
These conditions cannot be duplicated on the average DynoJet setup.
#36
Supporting Vendor
St. Jude Donor '09
Final numbers for the halltech super bee cf112 and katech cam and heads package
606.42 RWHP/535.26lbs-ft Torque* final pull with Halltech Super Bee CF112 and Super Beehive. The new cam the KAVORKA is and animal!!! (MY NAME FOR THE CAM.) In three days, we have added 45 RWHP/10lbs-ft torque, and dropped another 10.5lbs weight with our carbon rear quarter panels.
We are just 30 days and counting for the Carbon Revolution Wheels which are -52 lbs lighter than our OZ wheel, PSC combo. The only parts left on the UlLZ700 not carbon are the doors and fascia. Total weight should be around 2759lbs no fuel.
#37
Great numbers
Any idea on how much the heads added versus the cam maybe 50% and 50%? The heads were ported correct?
#38
Cheers, Paul.
#39
Yes, heads were ported. We believe that the heads enhance the camshaft and the camshaft works better with the ported heads (taking advantage of the higher lift). It's a system that works together and if you single them out individually I don't think it would add up to 100%.
