[Z06] Remote Clutch Bleeder ?
Wait until it needs a clutch to do a bleeder. Yes the TT needs to come out to install it.
First time out of the box there was a burr in the a/n fitting that made it leak so it wouldn't bleed. Had to have the end redone at a local place to get it to seal. 2nd time the machined fitting that screws into the slave broke in 1/2.
Had a Tick one fail on me a month or so ago on my F-Body. Really liked having a speed bleeder but am worried about installing one again and having it fail. I'm doing a Tranny/Clutch swap in 2 weeks.
Has the Katech Bleeder ever failed anyone?
I hesitate to suggest a Rube Goldberg cheapy Camaro fix in this exalted forum, but I had a similar problem on my LS2 402 equipped 98 Camaro and resorted to a mityvac pulling vacuum from the bottom of the clutch fluid reservoir. Worked well on my Spec 3 clutch.
We offer a few as well. I recommend the speed bleeder as it has a one way check valve built in making it a one person job and it reaches all the way to the engine compartment so you can access it remotely without jacking up the car, just be sure you secure it.
http://www.monsterclutches.com/shop/...edbleeder.html
Someone said you could reach the bleeder with a small wrench (driver's side) and thin arms without removing anything. I have thin arms and tried various ways for 15 minutes with the car on jack stands to find the bleeder screw with no luck. Some say you need to drop the cat.and/or midpipe.
Given the work, save it for a list item when/if you change your clutch. I've driven manuals for 50 years and have yet to change a clutch on any of my cars due to wear, street driven or race only.
Are there other remote clutch bleeder alternatives beyond the KaTech solution that you would recommend ?
http://store.katechengines.com/c6-re...-kit-p96.aspx\
How do you know yours has failed?
I think my bleeder from tick is leaking at the tip while I drive. If you tap the tip on something, fluid comes out.
Also the plastic floor that sits below the tip of the bleeder is wet like its been getting fluid regularly.
I am having issues with my clutch system right now. It seems like Im only getting the clutch to disengage 70-90% based upon if its been ten minutes since I bled, or an hour.
Dave
What broke on yours?
Also the plastic floor piece that you remove to gain access to the master cylinder area, is wet.
Dave
Dave
(I think this is what happens when you let friends take a turn behind the wheel and they dont know how to drive a clutch real well anymore.)
Im also curious if this is my issue on why Im not getting full disengagment of the clutch.
First thing Im going to do is contact tick about getting a new tip for my bleeder that is leaking.
Dave
