[Z06] Crate Z06 427 engines hand built?
My 2007 Z06 engine threw a valve and the engine needs to be replaced. The core is completely trashed.
I ordered a crate 427 engine from Chevrolet and it arrived @ the dealership today. We inspected it and noticed it doesn't have the "Build Center" plate with an "Assembled with Pride" name info.
I thought ALL 427 Z06 engines were hand-assembled, but I guess replacement crate engines aren't so they don't have the name plates?
Are we missing something?
Apparently they are "hand built" as well.
http://forums.corvetteforum.com/c6-z...post1582892089
http://forums.corvetteforum.com/c6-z...post1579075060
http://forums.corvetteforum.com/c6-z...post1579073275
http://forums.corvetteforum.com/c6-z...post1582118149
http://forums.corvetteforum.com/c6-z...post1581973432
What did the new crate motor set you back, if you don't mind my asking.
The hand assembly means little or nothing. It is basically a marketing gimmick unless they are concerned with fault traceability or parts control... the engines are not blueprinted.
They probably couldn't fit "Built with pride by Estaban Julio Ricardo Montoya la Rosa Ramirez" on the name plates, so the crate engines just come without them.
The real question is are you paying out of pocket or did Chevy help and/or cover the full engine?
I was leaning towards getting my heads redone once my warranty expires but now I'm not so sure. Might wait an extra year
As an example, I went thru 16 new valve springs today with one new retainer. The clearance between the OD of the retainer and the ID of the spring was supposed to be tight, but do-able (.640" retainer lock pocket OD vs. .650" spring ID (beehive)).
There was at least one spring that did not properly clearance the retainer (retainer did not seat completely), and had to be be 'adjusted' slightly. In a mass production environment that retainer would have been slapped on that spring and would have been 'worn' to fit (likely spiking the titanium wear metal count on a used oil analysis) or simply would have failed something or left that particular valve with an over-spec spring pressure by some .010" or so (not a lot, but not in line with the rest of the valves).
At final assembly all retainers will have to be checked as well to confirm that they conform in size specification to the one specimen used today.
The fit of the spring seat/ID locator was checked for all 16 springs as well... there were no issues on that end (altho the springs were radiused by hand on both ends to ensure that no sharp edges or burrs dug into the inside edge radius of seats or the retainers).
Bottom line, slapping an engine together by hand doesn't mean any particular effort such as the above has been expended in ensuring that all the parts fit and interact like they are supposed to. That is not a dig at GM, since they really can't afford that type of attention on each Corvette engine, but it is a wake up call to those that think that marketing claims have much validity or that engine failures are necessarily a result of faulty components rather than the more likely scenario of less-than-ideal mass-production-hurry-up assembly.
going by that that tongue in cheek reply does that mean these engines are made in mexico now ? na surely not , but answer to original post who give a rats a-----s who built it as long as its built by human beings and goes back in your car and goes well just put your little plate on your new engine ,hey one other thing why dont you make a neat coffee table out of the old block ,i did it with a LS1 engine great talking point in the workshop over an arostotle or 2 .
To the best of my knowledge all new LS7's are hand built by us at Wixom. And yes, a complete engine should have builder name plate attached in the normal location (top of intake manifold bracket).
However, a new long block will not have a name plate. Long blocks are built without intake and exhaust manifolds, flywheel, clutch, front balancer, water pump, spark plugs, etc. Since a long block does not have an intake manifold, we do not have a location to attach the name plate. If you have a new LS7 long block the manifolds and other parts are installed by your dealer service team.
