C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] How many quarts of oil?! Smh
Old 09-03-2013, 11:14 PM
VictoryRedZ06
VictoryRedZ06's Avatar
Default How many quarts of oil?! Smh
It's oil transfusion time Vette Fam, how many quarts tho? Thanks in advance for any inputs
Old 09-03-2013, 11:18 PM
RamAir972003
RamAir972003's Avatar
What year
Old 09-03-2013, 11:28 PM
VictoryRedZ06
Originally Posted by RamAir972003
What year
2006 brotha...what's the difference?
Old 09-03-2013, 11:33 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
The size of the sump tank increased in 2009 and up models.
Your oil fill is 8 quarts.
Old 09-03-2013, 11:37 PM
VictoryRedZ06
Thanks '06 Quicksilver Z06...Should I put 7 first measure it, then the 8th or all at once?
Old 09-04-2013, 12:07 AM
'06 Quicksilver Z06
7 first then run it some and check it
Old 09-04-2013, 12:15 AM
VictoryRedZ06
Ok sounds like a plan thanks
Old 09-04-2013, 01:05 AM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Old 09-04-2013, 01:28 AM
RamAir972003
I would start with 7.5 start it then see where its at 8.5 if your road racing it....
Old 09-04-2013, 09:03 AM
u1arunit
u1arunit's Avatar
My '07 Takes 8.5 qts with a filter change after a complete draining.
Old 09-04-2013, 09:12 AM
VictoryRedZ06
Thanks everyone, also how do you reset the oil percentage monitor?
Old 09-04-2013, 09:42 AM
'06 Quicksilver Z06
8 will get me between the bottom dot and middle dot when oil is checked according to the manual.
And BTW Victory Red, make sure you follow the correct procedure for checking your oil for the dry sump to guard against overfilling.
8.5 quarts puts me on the middle dot, but I've found this to result in higher incidence of getting oil into my intake so unless I was doing road course driving, I'll stay at 8.
Of course, others may have different results and do fine at the middle dot.
Old 09-04-2013, 12:07 PM
LMB-Z
LMB-Z's Avatar
Does your car have an owners manual? Look in the glove compartment. If you don't have one, I highly suggest you get one. Look on the big auction site, you can probably find one there.
Old 09-04-2013, 12:39 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Because if he doesn't know the capacity, he also needs to know the procedure.
Old 09-04-2013, 12:43 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Remember that you don't check it cold. The car needs to be ran and up to temp then you wait 5-10 minutes to check the oil. If you just add 7-8 quarts it won't even show up on the dipstick cold and you will keep adding and land up overfilled. I would start with 7 and then add until it is where you want it. Zs are picky about overfilling. I overfilled once by about a quart and it all just got burped out into my oil filter causing a huge mess/smoke/dripping/nasty time.
Old 09-04-2013, 01:32 PM
carpe dm
carpe dm's Avatar
Old 09-04-2013, 02:01 PM
pkincy
pkincy's Avatar
I was able to find an owners manual pdf for download. Not the Helms but the glove box owners manual.
Try that.
To How many quarts of oil?! Smh
Old 09-05-2013, 10:00 AM
VictoryRedZ06
Lol thanks everyone owners manual says 8 qts total, put 7 in first start it for a few seconds let the oil circulate then add the 8th quart putting all 8 all at once could cause it to overflow Any filter suggestions tho?
Old 09-05-2013, 10:28 AM
u1arunit
u1arunit's Avatar
Mobil 1 M113 for my Z.
Old 09-05-2013, 11:56 AM
Unreal
Unreal's Avatar
Not what I would do. I would add 7, let the car warm up then check it per the owners manual and add more oil until it is where you want.
Quick Reply: [Z06] How many quarts of oil?! Smh
