[Z06] 2008 Z06 Plug Unplugged Tranny
Went under my car for the first time since I bought it and saw this plug that was unplugged on the side of the tranny, not sure if it the cags plug or not. Only got 2 pics, but it's the side of the transmission on passenger side, if you look from rear of car.
The CAGS solenoid is on the driver (left) side of the tranny near the rear of the tranny and up rather high as I seem to remember having installed three CAGS Defeat resistors on past M6s.
Received 8,927 Likes
If it was the CAGS plug and unplugged without anything inserted into the connector there would have been a code set and you would have had a CEL. The CAGS defeat plug or a resistor are plugged into the open connector at the end of the harness to keep the CEL from lighting.
Bill
Bill
just plug it back in, it should be anyway. and you can check your lights yourself. put in reverse with the engine off, key/button in on position. accessory/on. the go take a look. easy. and yes, they might have unplugged it to install the exhaust. sometimes guys do it for just a another 1/2 inch clearance and to help avoid breaking it.
