[Z06] super dot brake fluid for mantic 9000 clutch?
Well I def go motul if your ******* on it. If not just get the Preston dot 4.... Should be fine I would run it for 2 weeks and change it again then change it again after 2 months depends on color. Hope this helps you
Received 8,928 Likes
I use Pentosin Super DOT 4 in my stock clutch. It is a low viscosity fluid.
http://www.crpindustries.com/pentosi...uperDOT4_2.pdf
You can buy it online from various sources. I got mine from Amazon.
Bill
Bill
