C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Is it safe to run the 1/4 mile without ABS fuse?
Old 09-30-2013, 11:46 AM
stealth1281
stealth1281's Avatar
Default Is it safe to run the 1/4 mile without ABS fuse?
I borrowed a set of 17 inch c5z06 wheels/tires for my c6z06 for the track. Shortly after putting them on, the tire pressure light came on. The car wouldn't allow me to set it to competitive mode and my times greatly suffered. Someone suggested to pull the ABS fuse and when I did I got these:
Service traction control system
Service Active handling system
Service ABS system
Service tire monitor system
I drove it around a little and it didn't go into limp mode or anything and the car felt fine. Are there any consequences to driving and racing the car like this? Thanks in advance.
Old 09-30-2013, 12:19 PM
EvilZ51
EvilZ51's Avatar
Service ABS system
Not sure on this but you could always just swap the wheels at the track to avoid the issue. I don' think it throws the code until after 50 miles.
Old 09-30-2013, 12:32 PM
stealth1281
I tried unhooking the battery with the ABS fuse in place to reset it and the tire monitor pressure light went off for a while, but I was still unable to get it in competitive mode.
Old 09-30-2013, 04:20 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
No need to remove the fuse as the car will run exactly the same with only just turning off the traction control.
Old 09-30-2013, 04:46 PM
dmuellenberg
dmuellenberg's Avatar
If I understand the OP correctly, he is saying that unless he pulls the fuse, he can't switch it to comp mode (and turn traction control off).
Old 09-30-2013, 05:15 PM
KLLRVET
KLLRVET's Avatar
Never run in comp mode, just run with traction control off.
Old 09-30-2013, 05:39 PM
erikszr1
erikszr1's Avatar
no need
Old 09-30-2013, 08:28 PM
gmkillr
gmkillr's Avatar
Were you the guy in the orange Z06 at PRP last Friday?
Im the guy in the yellow Z06 that you were talking to.
Old 09-30-2013, 11:01 PM
stealth1281
Yep, that was me. I'm heading up again Thursday.....
When I went to the track with stock tires, I shaved a half second off my quarter mile time putting it in competitive mode as opposed to running with just the traction control off. There was a noticeable difference.
Old 10-01-2013, 07:08 AM
gmkillr
gmkillr's Avatar
Yes i'll be there Thursday for T&T too.
I run with traction control off and have no issues.
Old 10-01-2013, 09:36 AM
stealth1281
Awesome. I'll see you there!..........
Oh yeah? That's interesting... I thought I read somewhere that stability control will apply break pressure to any wheel that begins to slip, but I could be wrong. If this is true, I would think between the launch and 3 shifts, my 1/4 time would suffer.
Old 10-01-2013, 07:49 PM
Supporting Vendor
If you did run faster then I can assure you it was a total fluke and with street tires that makes comparing one run to another even less useful.
I've got several thousand passes on my car and there is no difference between just turning TC off vs having everything off that'll affect your ET in any way. When you're able to produce timeslips from back to back passes showing very similar 60ft times but noticeably better ETs you might have a stronger argument but until then...
Old 10-01-2013, 09:10 PM
KLLRVET
KLLRVET's Avatar
Turning to comp mode will raise your risk of a crash, it will not help your et.
I have run mid 1.4 sixty fts with comp mode active...
Old 10-02-2013, 10:34 AM
stealth1281
My Trans Am didn't have any traction control or active handling and I never came close to losing control. Are vettes really that different?
I can't activate comp mode with the tire pressure light on...
Old 10-02-2013, 11:38 AM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
I think you are confused by the nomenclature. When you push the button, you are not adding anything. The nannies are active by default. You can de-activate them (aka turn off the nannies) with the button during an ignition cycle. Comp mode is desirable for road racing, autocross, etc, where low tire pressure is a detriment to handling, but not necessary or justifiable for drag racing.
Old 10-02-2013, 01:23 PM
stealth1281
Thank you for the clarification. This is all new and a bit confusing to me.
Old 10-03-2013, 07:09 AM
KLLRVET
KLLRVET's Avatar
Sorry for confusion, I'm just trying say turn off traction control only
To Is it safe to run the 1/4 mile without ABS fuse?
Old 10-03-2013, 08:09 AM
stealth1281
No problem; I want to learn as much as I can.
Thanks for all the help!
Old 10-03-2013, 11:47 AM
stealth1281
This is what really confuses me and makes me think AH is hurting my ET since it is applying the breaks on every shift:
“Competitive Driving Mode” (TS-Off and AH-On in its less aggressive form); DIC message is set. Entered via two pushes of the button. “Competitive Driving Mode allows the driver to have full control of the rear wheels while the Active Handling System helps maintain directional control of the vehicle by selective brake application.” [source Owner’s Manual p. 4-12]
EDIT:
After reading some threads from "Ranger," I have a much better understanding. Thanks again for the help
Old 10-03-2013, 02:18 PM
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
AH only is invoked when the car gets a little sideways.
If you are on a 1/4 run and you get sideways, you need to lift! AH will have already tried to correct the car for you though provided you were that far sideways. A few inch sideways should not have AH intervening.
What is likely happening on the shifts is torque management is cutting power slightly if you are spinning a lot on the shifts, not AH. TC MAY as well, but if you are spinning badly you are likely overpowering the TC anyhow...another reason to just lift as your time will be poor anyway. No sense beating on the car for a bad pass, right?
As for the tire pressure light, you have 2 choices. 1) swap wheels at the track and you will be fine all day. 2)Get Tire pressure monitoring sensors (TPMS) for the drag wheels, BUT you'll have to also have a TPMS reset device to reset all 4 TPMS when you put the rears on AND when you swap back to your daily driver wheels out back.
Ron
Quick Reply: [Z06] Is it safe to run the 1/4 mile without ABS fuse?
