C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Z06 ISSUE.........what the hell!?!?! HELP!!!!
Old 10-02-2013, 10:38 PM
66WES
66WES's Avatar
Default Z06 ISSUE.........what the hell!?!?! HELP!!!!
'09 Z06. Never had a problem with the car until tonight.
Went out in the garage to start it and the dash lights come on; hit the ignition button and nothing. Dead, won't start. Dash lights and speedo/tach instruments are sweeping, coming on/off. Readout says" serivce anti-lock brakes and active handling." Also reads battery saver is on. I had to use the emergency door release to get out cause the car locked me inside. The dash lights remain on, headlights/taillights remain on. I cannot re-enter the car and the rear hatch won't open when using the FOB.
What the hell is up? Anyone ever experience this type of issue? Yes, its still under warranty.
Old 10-02-2013, 10:40 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,664 Likes on 1,065 Posts
Replace your battery.
Old 10-02-2013, 10:44 PM
DaOtherOne
DaOtherOne's Avatar
Old 10-02-2013, 10:45 PM
66WES
66WES's Avatar
Thanks, Evil. That was my first thought. However, the all the exterior lights and interior lights are on and have been for 2-3 hrs straight now. I CANNOT enter the car to turn anything off or get to the battery.
Is there another way to get in the car without using the FOB?
Old 10-02-2013, 10:48 PM
VetteVinnie
The way to get the car open without the FOB is to use the key in the fob. There's a keyhole above the rear license plate and a release cable under the hatch on the left hand side.
Power to handle the lights is very different from the cranking amps required to turn over the engine.
Old 10-02-2013, 10:49 PM
seamus2154
seamus2154's Avatar
The key in your key fob is used to get into the trunk and the key hole is facing up by the license plate. These cars go nuts w/ a weak battery.
Old 10-02-2013, 10:52 PM
66WES
66WES's Avatar
Damn! I read the entire manual when I bought the car and don't remember reading any of that.......lol. Thanks guys, I will try it. I remember seeing the cable in the rear hatch.
Now, with the lights on and nothing working with the FOB, what procedure should I use when disconnecting the battery. Don't want to ruin anything or burn anything up. Will not touch anything until I hear back from ya'll........
Old 10-02-2013, 10:56 PM
VetteVinnie
No procedure. Just disconnect it. Getting it out of that hole is the hardest part.
Stuff will relearn once you plug in a new battery. It should even retain the radio presets (mine did). Just don't try to get it to pass a Smog inspection anytime soon. Disconnecting the battery resets all of the emissions sensors.
OnPoint
The Consigliere
OnPoint's Avatar
Received 5,432 Likes on 2,268 Posts
When the batts are on their death bed these rigs freak out with all sort of weird electrical shenanigans.
Old 10-02-2013, 10:58 PM
1Sikstik
1Sikstik's Avatar
Did you leave the ignition switch on when you tried to start it? Just disconnect the negative then the positive if removing it completely, you wont hurt anything. Is the OEM battery?
Old 10-02-2013, 11:02 PM
66WES
66WES's Avatar
LOL! Guys, thanks for the help. Had not ever had an issue with this car since new ownership until today. Freaked me out. Read the manuals, but that was so long ago I forgot about the FOB key. Tonight was the first time I ever took the FOB key out and even looked at the keyhole.
Appreciate the short notice help! Headed to get a battery as soon as the wife gets home.
Any recommendations? I am in Arizona, so the car does not deal with harsh weather and is always indoors unless being driven.
1SikStik, its the OEM battery. Yes, the igniton switch was left one, but its off now. Lights are off too. Headed to buy a battery.
Old 10-02-2013, 11:09 PM
CQT
CQT's Avatar
I had this happen to me too. If you have a battery charger then just change up your battery. Drive to the dealer tomorrow and they should replace the battery for you under warranty. Will, the dealer I want to did.
Old 10-02-2013, 11:42 PM
66WES
66WES's Avatar
Battery out; Done. Trick to get the battery out in 5-sec. Use a pair of vicegrips on the positive terminal (with some sort of insulation-I used foam), put right hand in open area on right side of battery housing opening and pull straight out; easy. I will drive to get a new battery tomorrow after work versus tonight. Thanks again fella's............
Old 10-02-2013, 11:44 PM
ByByBMW
ByByBMW's Avatar
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Just FYI, I find that in the C6, 4 years seems to be pushing how long a battery lasts. You are probably beyond that now.
Old 10-02-2013, 11:58 PM
ghoust
ghoust's Avatar
I invested in a battery holder, 20 dollar buy from the local parts store, now pulling the battery out and carrying it around is a breeze. I will have to do the battery change in my wife's car in a few months here so i will be using it again shortly.
Old 10-03-2013, 02:50 AM
brians98ss
brians98ss's Avatar
Living in Arizona myself, I usually replace my battery every 2-3 years. The summer temps out here will definitely affect battery lifespan.
Also, whenever I get back home after driving I will open the hood to get all that heat out of the engine bay. May or may not help but I like to think it is doing some good.
Brian
Old 10-03-2013, 08:32 AM
capevettes
capevettes's Avatar
Received 4,543 Likes on 2,159 Posts
2016 C2 of Year
2015 C3 of Year Finalist
It wouldn't hurt to get yourself a good battery tender like a C-Tek 3300 to use if the car is going to sit for prolonged periods. There are alot of systems in these cars that are kept in maintenance mode while it sits that can cause the battery to run down.
To Z06 ISSUE.........what the hell!?!?! HELP!!!!
Old 10-03-2013, 08:52 AM
RedZ4me
RedZ4me's Avatar
Mine lasted 3 years........even with Ctek tender on it every so often. You need a battery
Old 10-03-2013, 01:32 PM
Oleman
Oleman's Avatar
Just replaced mine at 3 yr age as well. Did not strand me but started doing odd things. Replaced now all is good.
Old 10-03-2013, 01:35 PM
b4i4getit
b4i4getit's Avatar
Brian
This would not help the OP. The Z06 battery is in the rear.
Quick Reply: [Z06] Z06 ISSUE.........what the hell!?!?! HELP!!!!
