C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Trans issue after rebuild and mantic 9000
Old 10-28-2013, 08:48 AM
billybadd
billybadd's Avatar
Default Trans issue after rebuild and mantic 9000
Alright guys need some help/advice.... 08 Z
Long story short, my second gear took a crap after heads/cam/exhaust. Pulled the trans and took it to a local trans guy and had it rebuilt with the "latest" parts. While I had the trans out I went ahead and installed a mantic 9000 clutch. Got the trans back and put everything back together and ran into an issue.
The shifter is popping out of first gear. It almost feels as if it doesn't engage or go all the way in to first. Every other gear including reverse feels ok.
If you put it in first and let the clutch go sooner and it bucks a bit it'll kick it out instead of stalling out. The new clutch grabs pretty good so I'm getting used to it.
If I let clutch out slow and kinda slip it itll stay in first but it shouldn't pop out if I let the clutch out too soon
Anyone ever have similar issues?
Old 10-28-2013, 09:19 AM
Blackonblacksls
Blackonblacksls's Avatar
Could be shifter alignment
Old 10-28-2013, 11:00 AM
billybadd
billybadd's Avatar
I'll try that, thanks.
Old 10-29-2013, 01:32 PM
billybadd
billybadd's Avatar
Shifter/box alignment no worky
Old 10-29-2013, 02:54 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Syncro/blocker assembly would be my first guess. The 2008 cars should have a TR6060 in them and I believe they use a ball and socket style instead of the keys to hold it into gear....could be that isn't assembled right.
If you can not adjust it from the shifter box, I think the trans is going to have to come out.
Old 10-31-2013, 12:53 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
To Trans issue after rebuild and mantic 9000
Quick Reply: [Z06] Trans issue after rebuild and mantic 9000
