[Z06] Torque Specs
Torque Specs
Putting on a different exhaust on my '08Z and curious if there is any torque specs for the stabilizer bar brackets and for that matter, the torque specs for the exhuast to header bolts. thanks
Stabilizer Shaft Insulator Clamp Bolt 100 N·m 74 lb ft
Stabilizer Shaft Insulator Clamp Nut 95 N·m 70 lb ft
Sorry I don't have the mid pipe to cat pipe specs though..!
Here's a link to forum member David Farmer's great torque spec info - print it out, laminate it, and throw it into your toolbox:
https://dl.dropboxusercontent.com/u/...Z06-Torque.pdf
Here's a post in the forum with some links to some of David's other stuff (torque specs for other models, etc.), and on his FaceBook page he's got a great DIY alignment guide and some other good info:
https://www.corvetteforum.com/autocr...id-farmer.html
Bob
Bob
Thanks guys that helps a lot. Wow, pulling out that passenger side exhaust was a job! If I knew how hard that was, I would not have done it. Trying a factory ZR1 muffler for now.
