C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] New 450ci ls7 build
Old 11-07-2013, 02:53 PM
Daniel Hoffele
Daniel Hoffele's Avatar
Default New RHS 450ci ls7 build
New build 450ci 11.9cr 4.165x4.125
Just seeing what everyone thinks this is going in a 07 zo6 since my stock motor dropped a valve
block= RHS 4.165 bore
Crank and rods= Callies compstar
Pistons= Wiseco
Bearings= Clevite
Cam= 247/263 lift 624
Injectors= ac delco
Fuel= Holley fuel rails
Valve covers= custom fab
Catch can= Not sure yet
Lifters= PBM
Heads= Mast black label 305cc
Rockers= Ls7 with trunion upgrade
Intake= Ported Fast lsx-r 102mm
TB= NW 102mm
Timing chain= Comp
Oil pump= Ls9
Damper= Super damper
Headers= 2'' stainless works 3''with offroad mids and x pipe
Catback= 3'' Corsa
Clutch= Monster stage 3 with billet flywheel with new slave cylinder
Rad= Dewitts drop in with fans upgrade
Motor mounts= pfatd
WES C. @ Showme-Speed in Nixa, Missouri is building the motor for me
Old 11-07-2013, 03:05 PM
240sx2jz
240sx2jz's Avatar
make it ready for a supercharger??
Old 11-07-2013, 03:11 PM
Daniel Hoffele
i wish out of funds for now so thats why im sticking with 11.1cr...might supercharge later on
Old 11-07-2013, 03:13 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
That sounds mean. Who is going to do the build for you? Did you ever get any resolution with your warranty company?
Old 11-07-2013, 03:50 PM
Daniel Hoffele
Yah it should be around 600rwhp and a**load of torque...yep got 10k from the warranty company just enough to cover the short block
Old 11-07-2013, 05:52 PM
briancb1
briancb1's Avatar
Injector Dynamics 725's for the injectors.
I'd rather use a RHS high port cylinder head and get them professionally ported. Only raised port LS7 head on the market that's a true bolt on for the fast intake.
Old 11-07-2013, 06:21 PM
Daniel Hoffele
Heard good things about those injectors not sure what my build has got for the motor yet thou.
I looked at those heads but at almost 2k more than the mast heads I can't see them being worth that for .2" raised intake port but then again never used them or see any test the the rhs vs mast
As for as the fast intake my god did it need a lot of work. I have about 30hrs into that intake for something that cost that much is nuts. Just were the runners met the bottom of the intake took for ever to get them to match some of the runners were 1/8 smaller than the bottom intake
Old 11-07-2013, 06:26 PM
NHRA95
NHRA95's Avatar
That is a super great build! It'is going to be a monster!
Old 11-08-2013, 12:11 AM
briancb1
briancb1's Avatar
2K more than MAST's?! What masts are you getting and what RHS heads were you looking at?
Old 11-08-2013, 02:12 AM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Very cool, how exciting for you, best of luck, will be a MONSTER with great heads too!
Old 11-08-2013, 11:34 AM
Spec C
Spec C's Avatar
Was wondering the same thing. RHS Heads are like $3650 fully cnc ported by Frankenstein.
Old 11-08-2013, 03:13 PM
Daniel Hoffele
Mast Motorsports Black Lable Rectangular Port LS7 305cc 12 Degree 6-Bolt Large Bore CNC Assembled, Pair (GM LS Series)510-309 ss light weight valves list is $3499 i got them for $3180 Already bought couple months ago could upgrade to titanium but for 1.5k more but ill pass.
I see now they have the ss rhs heads which are really close to the same price
RHS Pro Elite LS7 Rectangular Port Assembled Head w/ 26926 & TI, CNC-Ported [291cc Runner | 69cc Chamber | 2.200" Intake | 1.615" Exhaust] ss valves part#54501-06STI list $3678 sell $3310
RHS Pro Elite LS7 Rectangular Port Assembled Head w/ 26926 & TI, CNC-Ported [291cc Runner | 69cc Chamber | 2.200" Intake | 1.615" Part #54501-06TTI these are titanium valves so that puts more cost on it list $5598 sell $5038
RHS Pro Elite LS7 Rectangular Port Assembled Head w/ 26926 & TS, CNC-Ported [291cc Runner | 69cc Chamber | 2.200" Intake | 1.615" Exhaust]Part #54501-06TTS $5550 sell $4996
had the valves mixed up mixed up so yah that adds alot of cost for sure
Dont think ill ever go to titanium valves thou since both my intake and exhaust valve guides were worn at 49k mile the exhaust of coruse were way out of spec
Old 12-22-2013, 09:19 AM
Daniel Hoffele
shaft mounted roller rockers worth it or just stick with the ls7 truion upgraded rockers?
To New 450ci ls7 build
Quick Reply: [Z06] New 450ci ls7 build
