[Z06] The "Out of Spec" Guide Wear Registry
#221
Me too
Add me to the list also.
2010, 21,500 miles, produce 12/09
No mods done....yet.
I bought this car 2 weeks ago knowing full well that I could have this problem. I am the 3rd owner. I put 500 lucky miles on it in 2 weeks.
Just got back from my shop where I keep it and my drag car.
Preformed the wiggle test (only on cly. #2 ex.) before I even set up the dial indicator I knew I was screwed.
.024 (yes you read that right, checked it 3 times).
I have replaced valves in cly. heads before where they only needed to be lapped in, built many of small and big block Chevy's (very high performance),I work on both diesel and gas engines in aerial lifts and telehandlers (Genie and JLG's) and I have never seen this kind of wear.
I am not going to take it to any dealer to get it fixed, if they cant do it right the first time how can I ever trust that the repair will be right (besides I don't like anybody else working on my car).
After I remove the heads I will come back and give the full read out of all clearances.
And let the mods began. Good time to put in cam and headers.
#222
Supporting Vendor
Received 1,012 Likes
This is a data thread
It is important to the corvette community that this thread remain data driven (as opposed to opinion/advertising driven). No disrespect intended, just want to see this thread stay data only and not get side tracked.
#223
Wiggle Results
Results are in. Not what I expected. I wrote in my first reply that it was #2 exhaust was out of specs, end up being the #2 intake.
Cly #1 in. .033
ex. .003
Cly #2 in. .024
ex. .005
Cly #3 in. .026
ex. .003
Cly #4 in. .019
ex. .005
Cly #5 in. .031
ex. .003
Cly #6 in. .016
ex. .004
Cly #7 in. .013
ex. .002
Cly #8 in. .018
ex. .0025
So my exhaust were pretty much in specs and intakes were shot.
Cly #1 in. .033
ex. .003
Cly #2 in. .024
ex. .005
Cly #3 in. .026
ex. .003
Cly #4 in. .019
ex. .005
Cly #5 in. .031
ex. .003
Cly #6 in. .016
ex. .004
Cly #7 in. .013
ex. .002
Cly #8 in. .018
ex. .0025
#228
#230
Cheers, Paul.
#231
These were wiggle numbers with the valve 1/2 in. down.
Intake valve stem measures .313 where there is no wear to .3129 where the stem was inside the guide.
I can live with .0001 wear.
#232
2008 Z06
20,000 miles, street use, never tracked
Wiggle test performed by American Heritage
Needless to say, the heads will be reworked by AH.
The following is my wiggle test results.
#1 int: .010"
#1 exh: .005"
#3 int: .0125"
#3 exh: .007"
#5 int: .0135"
#5 exh: .007"
#7 int: .012"
#7 exh: .0075"
#2 int: .011"
#2 exh: .0075"
#4 int: .0125"
#4 exh: .0065"
#6 int: .010"
#6 exh: .0055"
#8 int: .011"
#8 exh: .007"
#1 int: .010"
#1 exh: .005"
#3 int: .0125"
#3 exh: .007"
#5 int: .0135"
#5 exh: .007"
#7 int: .012"
#7 exh: .0075"
#2 int: .011"
#2 exh: .0075"
#4 int: .0125"
#4 exh: .0065"
#6 int: .010"
#6 exh: .0055"
#8 int: .011"
#8 exh: .007"
#233
Cly #1 in. .033
ex. .003
Cly #2 in. .024
ex. .005
Cly #3 in. .026
ex. .003
Cly #4 in. .019
ex. .005
Cly #5 in. .031
ex. .003
Cly #6 in. .016
ex. .004
Cly #7 in. .013
ex. .002
Cly #8 in. .018
ex. .0025
Cly #1 in. .033
ex. .003
Cly #2 in. .024
ex. .005
Cly #3 in. .026
ex. .003
Cly #4 in. .019
ex. .005
Cly #5 in. .031
ex. .003
Cly #6 in. .016
ex. .004
Cly #7 in. .013
ex. .002
Cly #8 in. .018
ex. .0025
2008 Z06
#1 int: .010"
#1 exh: .005"
#3 int: .0125"
#3 exh: .007"
#5 int: .0135"
#5 exh: .007"
#7 int: .012"
#7 exh: .0075"
#2 int: .011"
#2 exh: .0075"
#4 int: .0125"
#4 exh: .0065"
#6 int: .010"
#6 exh: .0055"
#8 int: .011"
#8 exh: .007"
#1 int: .010"
#1 exh: .005"
#3 int: .0125"
#3 exh: .007"
#5 int: .0135"
#5 exh: .007"
#7 int: .012"
#7 exh: .0075"
#2 int: .011"
#2 exh: .0075"
#4 int: .0125"
#4 exh: .0065"
#6 int: .010"
#6 exh: .0055"
#8 int: .011"
#8 exh: .007"
Perhaps the guides/install was fubar'd from the get-go?
Glad you caught it though!!!
#234
I thought it was interesting to do percentages of those who posted out of spec divided by the production numbers. Numbers are taken from Post #1.
THE OUT OF SPEC LIST: (stock powdered metal guides)
2006: 43 of 6272 produced (20.5% of production) = 0.63%
2007: 46 of 8159 produced (26.7% of production) = 0.56%
2008: 42 of 7731 produced (25.3% of production) = 0.54%
2009: 25 of 3461 produced (11.3% of production) = 0.72%
2010: 5 of 518 produced (1.70% of production) = 0.97%
2011: 5 of 904 produced (3.00% of production) = 0.55%
2012: 2 of 478 produced (1.60% of production) = 0.42%
2013: 1 of 471 produced (1.50% of production) = 0.21%
427: 0 of 2552 produced (8.40% of production) = 0.00%
#235
2009 Z06
7,666 Miles
Street use, Never tracked
Heads reworked by Katech Performance
Valve Guide Clearances done by WCCH
#1 - Intake = .0057
#1 - Exhaust = .0041
#2 - Intake = .0093
#2 - Exhaust = .0039
#3 - Intake = .0052
#3 - Exhaust = .0038
#4 - Intake= .0097
#4 - Exhaust = .0037
#5 - Intake = .0071
#5 - Exhaust = .0042
#6 - Intake = .0106
#6 - Exhaust = .0052
#7 - Intake = .0065
#7 - Intake = .0044
#8 – Intake = N/R [Too large for gauge]
#8 – Exhaust = .0038
7,666 Miles
#1 - Intake = .0057
#2 - Intake = .0093
#3 - Intake = .0052
#4 - Intake= .0097
#5 - Intake = .0071
#6 - Intake = .0106
#7 - Intake = .0065
#7 - Intake = .0044
#236
I just had mine gauged and Kohle from AHP said they were all in spec with 47k miles. I'll ask him what the numbers where on the measurements and report back.
#237
2006, All stock. Some track days but not abused. 10,300 miles.
Wiggle
tested your bank 1 head (driver side).
results are as follows:
#1 Exh: .0125"#1 Int:
.010"
#3 Exh: .013"#3 Int:
.009"
#5 Exh: .014"#5 Int:
.010"
#7 Exh: .013"#7 Int:
.008"
The are the raw wiggle test measurements.
The actual measurement is roughly half of the wiggle test
measurement.
Wiggle
.010"
.009"
.010"
.008"
measurement.
#239
Added
It did take some time, Ricky definitely pulled a chunk out for me and most of the rest I found via google site: searches.
I agree on the contrast. Many people think their car is fine because it hasn't had a failure, yet if you compare those that have actually measured or inspected the guides, it is 10:1 out of spec vs in-spec.
I'll be on one list or another in a couple weeks.
#240
I guess I get to be added twice.. I bought a set of used heads (off of a 2013 427 vert) with a whooping 4k miles (yes 4k), and low and behold, exhausts are fine, but all the intakes are out..
Thought I'd save some cash, slap the roller rockers on them and call it a day.. Not a chance, they will need to be reworked.. At least I won't be down for more than a weekend.
Trust me my friends, this is geometry / design / factory tolerances problem, not a "you have bad luck" problem..
