[Z06] The "Out of Spec" Guide Wear Registry
#402
Add me to the list
Please Add me to the list.
Stock 2008 Z06 with 13,500 miles
all (8) exhaust out of spec, (3) intake out of spec (5) intake only in spec by .0001-.0004
Measurement done by Katech/WCCH
can provide data if needed
#403
213 427 with just over 6,000 miles Intake valves guides were the worst, exhaust valves guides not very good either, valves, guides,springs heads replaced over $2,000.00. Valves were checked while at DRM for cam/headers/CAI. Waiting on heads to come back before build can be finished.
I have the heads in my garage if you want to check it out before I send them back for the core refund.
#404
My valves where bad as well, I can feel movement with the valve springs still installed. But Todd said they weren't nearly as bad as yours. Crazy since mine has over 43,000 miles on it with stock cam/valvetrain.
DH
#406
Just made it a few minutes ago!
C6 Z06 LS7 valve wiggle test #1 - YouTube
C6 Z06 LS7 valve wiggle test #2 - YouTube
Like I said in other thread. Hopefully you will match up the actual measurements to the video
Thanks !!
DH
#407
Received 8,918 Likes
I didn't video the movement of the valves after the shop measured my guides with a guide bore gauge but afterwards I installed valves in some of the guides that were well within spec along with some in the guides that were out of spec. Even the guides that had clearances around .002 allowed the valves to wiggle to some degree.
https://www.corvetteforum.com/forums...post1589205160
A wiggling valve isn't necessarily an indicator of a bad stock guide, it depends on how much it wiggles. The guides that were out of tolerance allowed the valve to wiggle a lot. The guy that owns the shop that is working on my heads it takes a lot of experience to grab the valve and feel how bad the wiggle is.
Bill
#410
Add me to the list.
2011 C6 Z06
40k miles
Bone Stock
street driven (maybe once a week)
Test done by: American Heritage Performance
Here's the numbers:
#1 exh .0065"
#1 int* .009"
#3 exh* .005"
#3 int* .0075"
#5 exh* .006"
#5 int* .010"
#7 exh* .0075"
#7 int* .011"
#2 exh* .006"
#2 int* .010"
#4 exh* .0055"
#4 int* .009"
#6 exh* .0065"
#6 int* .0095"
#8 exh* .007"
#8 int* .010"
2011 C6 Z06
40k miles
Bone Stock
Here's the numbers:
#1 exh .0065"
#1 int* .009"
#3 exh* .005"
#3 int* .0075"
#5 exh* .006"
#5 int* .010"
#7 exh* .0075"
#7 int* .011"
#2 exh* .006"
#2 int* .010"
#4 exh* .0055"
#4 int* .009"
#6 exh* .0065"
#6 int* .0095"
#8 exh* .007"
#8 int* .010"
#412
#413
Received 1,116 Likes
2007 Z06 w/36K miles
Driven vigorously but not to extremes. No track, just a few autocrosses. Doubt I've ever gotten to 7K.
N/R means “No reading” (Quote from proheads.com - WCCH) "It was off the scale so bad we were unable to get a reading.
In for new guides, SS exhausts, beehive springs.
These are all "hourglass" shapes which must mean something about the forces applied to the valve stem. Probably these wear patterns are ovals and their orientation would suggest something about the rocker geometry.
"GM, where's your pride? Where are your engineers?"
#414
Add me to the list
2006 C6 Z06
52,000 Miles
Daily driver (25 miles a day average it sees)
Mods:
Cold air intake
Deleted mufflers
Shop measured one intake and one exhaust
Intake - .013
Exhaust - .030
Drove the car 32K miles before checking the heads. Luck is on my side.
2006 C6 Z06
52,000 Miles
Mods:
Cold air intake
Deleted mufflers
Intake - .013
Exhaust - .030
#415
Just to clarify, based on the information you posted in another thread, these measurements were from a wiggle test. From other results comparing the wiggle test to actual heads off measurements you should divide the wiggle test measurements by roughly half, so the intake would be around .0056 and the exhaust .015. These measurements, especially the exhaust, are still on the extreme side. This also assumes that the wiggle test was done accurately as GM claims that a wiggle test measurement is difficult to perform accurately with the heads still on the vehicle.
#416
#417
Don't think the valves will not move on an in spec valve guide.
Bill
Bill
I'm curious where you get your information from...I have a fresh set of heads here at home none of the valves wiggle like his did...like I said before this is an issue that is affecting all years 2k miles 64k like mine....chances are you check the heads by doing the wiggle test like in video above chances are they are out of spec period...moving like that..maybe not bad maybe real bad..its not worth taking a 15k gamble.
#419
