[Z06] Cunningham Motorsports heads/cam packages
Here is another C6 z06 we completed with our Heads/cam package... 575 rwhp 505 rwtq
CMS H/C package c6 z06 - YouTube
Hey Ryne- I know this is an older thread, but are these prices still accurate?
Here are some of the packages we offer for the C6Z06 cylinder heads. We have a few packages ranging from a basic fix of the heads to a performance heads/cam tailored package. We use West Coast Cylinder Heads for all our cylinder head work. Their quality is second to none and they simply stand behind their product.
-Basic repair (repair of your current LS7 heads):
WCCH removes all valves, replaces exhaust valves with a one piece solid stainless steel valve (rev brand), sends intake valves to Delwest for tumble polishing, replaces all guides are with CHE custom length (per WCCH spec) guides, performs competition valve job, and surface clean and re-assembly is done. This is for parts only utilizing your current heads.
BTR platinum dual spring kit is included in this package along with a new set of LS7 head gaskets and ARP head bolts.
This package is $1580 plus applicable taxes for parts only.
All items above installed for $2400+ tax (this includes parts, Amsoil and wix oil filter)
-Heads/cam Performance package:
WCCH performs all head services mentioned in the basic repair package, plus a stage 2 CNC port and flat milling of the head to CMS spec.
Cometic .040 head gasket (to tighten up quench area)
New OEM LS7 lifters, Manley 3/8" pushrods (7.8" lenth), ARP head bolts,
CMS custom grind camshaft package (we have three different cam grinds that we recommend for most customers but can customize specs based on certain situations.)
All required gaskets and new crank bolt.
This package is $3100+ applicable taxes for parts only.
All items above installed and custom dyno tuned for $4800+ tax (this includes parts, Amsoil, and wix oil filter)
Here is a dyno video of one of our mid level heads/cam packages .
Here is an idle clip of another car with our mid-level cam packages.
if you guys have any questions, please feel free to email me at Ryne-cms@hotmail.com. Thank you
i need to ask you about the two video you post it , whats the parts different btween the two car one of the bring in the dyno 567rwhp and the another one 600hp ?
