C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] cannot reprogram FOB? need help
Old 01-12-2014, 03:46 PM
Joshua Detwiler
Joshua Detwiler's Avatar
Default cannot reprogram FOB? need help
I had my #2 FOB lost/stolen........ whole other story, so I got a new #2 FOB and I went through the steps 1-6:
roll down windows
open glove box
place working FOB on console
(I keep the un-programmed FOB in my pocket)
put key in cylinder and open rear hatch then turn key 5 times less than 5 seconds
My DIC never says anything about learn or program FOB like its supposed to?
I tested my glove box FOB reader by taking the battery out of the FOB and placing the FOB in the slot and the car starts
what am I doing wrong here?
my car is a 07 Zo6
Old 01-12-2014, 06:32 PM
Joshua Detwiler
any inputs?
Old 01-13-2014, 01:02 AM
dmuellenberg
dmuellenberg's Avatar
The manual says that the car must be in reverse. Could that be the issue? Other than that, looks like you are doing things correctly.
Old 01-13-2014, 09:08 PM
Joshua Detwiler
that didn't work either, the only thing that happens is the yellow padlock icon blinks on the dash next to the speedo
Anyone else got any ideas or know what the dealership would charge?
Old 01-13-2014, 09:31 PM
NavyAirTraffic
NavyAirTraffic's Avatar
C6 Comprehensive Fob Programming Instructions.... several different methods here to get the DIC into programming mode.
None of ^that^ worked for me. If you have another working fob the dealer will use a Tech II to just pair the new fob from the working one. I had to take this route, and they charged me $25. I have no idea how much they charge if you don't have a working fob. Good luck.
Old 01-16-2014, 12:29 AM
Joshua Detwiler
I have a working FOB and they still want 60 bucks, thats the lowest I could find in Las Vegas, one dealership wanted 120
Does anyone know if there is a DIY youtube video on this?
Old 01-18-2014, 01:02 PM
cjklekar
Cruising
cjklekar's Avatar
4. Put working fob on console next to shifter (the one you are currently using to drive the car)
Point #4; follow this and it should work. I was having the same issues until I put the working fob next to the shifter.
Extra fob now programmed. YMMV
Old 03-02-2017, 08:42 PM
rivernewman
rivernewman's Avatar
I got it! Put the car in reverse. Very important. Thanks! Feels good knowin I have a spare.
Old 03-02-2017, 08:50 PM
rivernewman
Default Fob program is it in Reverse.
Fob program put it in Reverse. I did program a #1 fob into a #3 fob.
When I saw my dic say program #3 I put it in the slot and did it. I never did check to see what is up between #1 and #2. I've only had the one fob the #2 fob.
Old 02-25-2018, 02:09 PM
HKH
HKH's Avatar
The fob needs to be in the slot in the glovebox with fob buttons facing the passenger side. Car manual explained it well.
Old 02-26-2018, 07:15 PM
dmuellenberg
This thread is almost a year old. Why are you reviving it? Not supposed to revive old threads unless you are updating or adding new information.
To cannot reprogram FOB? need help
Quick Reply: [Z06] cannot reprogram FOB? need help
