[Z06] NEW! Radical 102 Intake Porting for LS7's!
Former Vendor
Customer gets great gains from LS3 Radical 102 porting
Listen to what this recent customer says about his Radical 102 ported setup on and LS3:
“Just an update on how the install went, added the following nick williams throttle body and the ported LS3 intake along with meth injection and tune.
Baseline car made 484 RWHP and 434 Torque
After tune car made 521 RWHP and 466 Torque.
Showing some nice gains into the ported LS3 heads with LG G6X3 cam and ARH 1 7/8.”
Brian – Flower Mound, TX – LS3 Radical102 ported intake manifold & Nick Williams 102 throttle body.
Former Vendor
Radical 102 porting stands up well in force induction setups. The integrity of the manifold is maintained. They are not cut apart and reassembled with epoxy in the porting process. When the posts are removed inside the plenum, steel plugs are threaded into the base and epoxy is only used to ensure they don't thread back out. On the throttle body opening, the stock throttle body gasket is eliminated to enlarge the opening to 102mm. We have created a 102mm gasket that goes between the throttle body and the intake manifold to create a good seal.
If they are shorten, how much RPM is the curved extended?
Thanks! Looking forward to more info.
Former Vendor
LS7 Radical 102 ported by Peak Speed Shop
LS7 intake runners ported by Peak Speed Shop
Peak Speed Shop 102mm Gasket
Former Vendor
No direct comparison to be able to show at this time on the LS7. However, our Radical porting on the LS7 shows about the same gains as on the LS3 and the Radical 102 porting on the LS3 with the NW102 tb is picking up 23 RWHP. This is about the same as the FAST 102 on the LS3 with the NW102 TB at a much lower cost. I expect your LS7 to have similar gains.
#35
Former Vendor
Porting is our business and we are good at it!
Porting intake manifolds and throttle bodies is Peak Speed Shop's primary business. We do a lot of them and have gained a good reputation for high quality work and performance.
Our proprietary process of "Radical Porting" stock LS intake manifolds gains top results! In terms of cost per horse power gained, this is one of the lower cost modifications you can do. A weekend mechanic can easily do it in their garage.
Here is a link for step by step instructions that you can use on most LS cars:
http://www.peakspeedshop.com/removal.xhtml
For pricing on stock and FAST porting, go to our online store at:
http://peakspeedshop.com/Zen_Cart/
#37
Former Vendor
"The whole experience was....AMAZING!"
Listen to what this recent customer had to say about Peak Speed Shop....
“Amazing communications , amazing turnaround time and amazing product. The whole expirience was.....AMAZING!!! I will highly recommend your work to friends and fellow gear heads as well as use you again for my next project. Thanks...Stan.”
Stan - North Richland Hills, TX
#39
#40
Former Vendor
