[Z06] Need help >>I want to buy new head 6 bolt with cam shift for my short block ERL
There is any gays give me advice for the best head with cam shift.
I have new short block by ERL 434 6 bolt
I have supercharger by edlbrok eforcy 10 psi
And add shot150 hp
What the best heads and cam for this project ?
Also what size you thinks good to use 305cc or 275cc or mor or low
And add shot150 hp
Need any have smart gay or technical gays for mack head with cam shift.
And shot intros 150 hp
What the beast heads and cam for this project ?
Either at
www.onallcylinders.com
or
at www.Trickflow.com next month.
Heres the video they released at SEMA on the heads:
or
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,092 Likes
They come with all stainless solid valves so you'll need to limit revs to 6K. You'll need to call Trick Flow to see if they have a Titanium intake valve option. The hollow stem stainless exhaust would be a plus too.
some serious spellcheck needed there.
Wrong. A properly setup valve train will take solid stainless valves as high as you want to go.
Sorry gays for this wrong this is my second language
And add shot150 hp
And add shot150 hp
GM makes a six bolt LS7 head, and Texas Speed/PRC makes one (you'll need a six bolt head for what you described). Also Brodix. There are others but the price starts going up quickly.
I have no idea what kind of cam you would need for such a build. At the very least you'll need to talk to a cam professional who can probably give you some advice on heads too.
You need some serious heads for that project. I suggest you contact a serious engine builder for advice and maybe even for assembling the engine.
Thank you bro for all advice give to me
1- yes I need heads with 6 bolt
2- I saw the all pro heads and mast head or brodix heads or trick flow I don't know what the heads it best for me
3- do you have any num or company for talk to a cam professional?
Thanks again for your times
The Brodix heads with WCCH porting would be my choice.
