[Z06] Low 1/4 mile trap speed. Reasons?
#81
TRSCobra Are you coming out to racewars this weekend? I'm more than positive it's in your tune. I would bet money your car is showing false knock and pulling timing. I would also bet that the car is pulling timing by a min of two degrees before your even stage. Plus rxt clutch loves to be slipped, 5k plus rpm and slip her out of the hole.
Here's my na Z06 at the nw street car event. Hoosiers and stock fatties up front. I was pulling 4 degrees of timing before I even left the line. Left side #93
#82
ok on this subject here is mine, no slow shifts, no traction issues, going into 4th @ around 1000'
#83
So I went back to my tuner and he leaned it out to around 12.8. Came in at 473whp and left at around 493 (forgot to ask for a printout), but I gained ~20whp across the entire powerband. Went to a track rental yesterday and pulled my best time ever.
Tuner says I should be making more power with the heads/cam, and I'm considering changing it out, but I'm going to see how it responds to full bolt ons first. If I get 560 or more on his mustang dyno with halltech/nw102/msd/arh, I'll keep this cam. if not, a BTR stage 2 or 3 is likely going in.
Overall, I can't complain too much!
Is2scooby (10-26-2015)
#85
Forgot to press record on my best pass, but this is a decent one. I started powershifting. Not sure if it's helping more than if I lifted the throttle or not, though.
#86
#87
He had a bad WBO2 the first time he tuned it and it kept reading lean, so he kept adding fuel. He later replaced the sensor and reverted to earlier adjustments, but there must have been an error made. That's the only reason I can think of that it was so rich.
#90
Clutch Master
So how did you blow your clutch master? Isn't that rare? How many miles? how did you know? Never heard of this one... Did you put in a tick? Cheers, d'Art
#91
The master turned out to be fine. Turns out the stock disc with 28k miles exploded. I replaced the stock with a tick and the pedal was still to the floor, so I looked in the bellhousing and found a piece of the disc that broke off.
dart.deanda (10-26-2015)
#92
https://youtu.be/jWQpUK_4Z_c
If you can log a pass and it doesn't show wheel spin, then I'd say do it. If it shows wheel spin on the shifts, which it likely will, then I wouldn't power shift.
I never did on my passes.
Ron
TRSCobra (05-14-2016)
