C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 Wiggle Test DIY
Old 07-04-2014, 05:27 AM
kotik
kotik's Avatar
Awesome write up!
I have a set of heads from Kohle, and i test them daily on the autobahn! So far been getting 12 smiles per gallon to an awesome total of 4k miles! Customuer service and support is superb!
Old 07-06-2014, 01:50 AM
ilovemyredhotc6
ilovemyredhotc6's Avatar
So. Cal. Events Coordinator
How much does it cost to do this test at AH?
Old 07-08-2014, 08:07 AM
forg0tmypen
forg0tmypen's Avatar
Originally Posted by American Heritage
I first pressurize to move the piston down into the bottom of its bore. That way when I next remove the air pressure and hit the retainers with a socket and hammer the valves are assured to not contact the piston (as they do move down a little bit when you tap them with the socket/hammer. I do not tap the retainers with the air pressurizing the cylinder, this Is why I remove then reconnect the shop air.
Few questions:
What size rubber hose are you using?
How do you know when the piston is down to the bottom of its bore? I've read that you want the car in TDC so if a valve falls it will make contact and not be lost.
Is it possible to just leave the air connected the entire time until springs are off and hose is on to protect valves?
Old 07-08-2014, 09:17 AM
Michael_D
Michael_D's Avatar
The stem is 8 mm, so 1/4" hose would probably fit snugly. I used O'rings. They roll over the tip and lock into the keeper grove.
You will know when the piston is down the hole after a resounding "swish/thump" is heard, then it ain't going nowhere...... Oh, car needs to be in neutral.
Yes. You don't need to whack the retainer, although guys who work on heads all the time tend to do that to ease keeper removal. I have not ever needed to be that aggressive and spend a bit more time with foreplay...
Old 07-08-2014, 01:14 PM
flyby763
flyby763's Avatar
Is it possible to do this without an air compressor?
Old 07-09-2014, 02:03 PM
MyLastCorvette
MyLastCorvette's Avatar
Thank You, I'm still not ready to open up a near new engine, just yet...
Old 07-09-2014, 02:23 PM
ctsv510
ctsv510's Avatar
answered in another thread:
Why not use us:
American Heritage Performance
310-326-2399
http://www.americanheritageperformance.com/
http://www.yelp.com/biz/american-her...ce-harbor-city (check the filtered reviews as well, yelp likes to send legit reviews to the filter).
We are located in the south bay. Off the 110 freeway and pacific coast highway.
We have lots of C6 Z experience.
We also do our own LS7 cylinder head machining. We even have our own aftermarket powder metal valve guides that we use in our reworked package #4 LS7 heads.
We have three C6 Z06's in the shop at the moment getting their heads reworked.
We charge $150 to conduct the wiggle test (passenger bank only).
give us a call, email or shoot us a PM.
Old 12-11-2014, 10:10 PM
Chad22
Chad22's Avatar
What vender has the spark plug air hook up on here? Doing the wiggle test in a few weeks and gathering parts now.
Old 12-11-2014, 11:21 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
Available at Jegs or Summit for +/- $35
Moroso#710-62385
Universal Spark Plug Hole Air Hose Kit
Old 12-16-2014, 03:08 PM
Chad22
Chad22's Avatar
Thanks for the info and part #! After talking with my buddy who is helping me do the wiggle test he does not see why we need to use air pressure? He said he has done a few of these without using air? Can someone please break this down for me so i can explain it to him. Thanks Chad
Old 12-16-2014, 04:31 PM
Undy
Undy's Avatar
You're going to have fun getting the valve stem locks off and back on without air pressure holding the valve all the way up.
Old 12-19-2014, 05:07 PM
American Heritage
Supporting Vendor
American Heritage's Avatar
Received 1,012 Likes on 533 Posts
Originally Posted by Undy
I find that the valve stem locks/retainer tend to "stick", to the point that you'll open the valve with the spring remover (even under 130 psi) before you break the keeper free. I find it helpful to use a 3/4" socket with a short 3/8" drive extension and tap the top of the retainer down with the socket/extension to unseat the locks/retainer. Make sure you do this while the valve is under air pressure. A semi-light tap is usually sufficient. If the retainer is unseated you'll see it move down a tad while the valve stem remains stationary.
Fantastic job! This DIY should help a lot of people here.
The information you posted is already covered in this DIY.
The 2nd pic in our DIY shows how to break free the valve locks so they don't depress the valve when removing the springs.
Old 12-19-2014, 06:47 PM
  #33
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Posting links to other Corvette sites is not allowed:
https://www.corvetteforum.com/forums...ate-links.html
Also, if you have issues with this vendor's procedure, take it to email or PM and not in his thread.
Old 12-20-2014, 05:23 PM
  #34
AZDANZ06
AZDANZ06's Avatar
Old 12-20-2014, 05:43 PM
  #35
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Good write up...luckily I'm local to AH so I'll be bringing it to them for an inspection.
Old 12-20-2014, 05:46 PM
  #36
AZDANZ06
AZDANZ06's Avatar
I am not close, but making an 8 hour drive to have AH check my heads and fix if needed at the end of the month.
Old 12-20-2014, 06:06 PM
  #37
MTPZ06
MTPZ06's Avatar
Very Nice! Keep us all informed on what you wind up doing, and how everything goes.
To LS7 Wiggle Test DIY
Old 12-20-2014, 08:24 PM
  #38
AZDANZ06
AZDANZ06's Avatar
Will do, we are bringing two Z06's to him at the same time, my father in law has a 2006 Z. I am fighting the temptation to have him port the heads and do a cam and tune
Old 12-20-2014, 08:39 PM
  #39
MTPZ06
MTPZ06's Avatar
Awesome! If you guys wind up anywhere near South Orange County and you like good craft beer and great BBQ, just hit me up...I know a good spot real close to my house.
Old 12-20-2014, 08:53 PM
  #40
AZDANZ06
AZDANZ06's Avatar
Will do, if the valves are out of spec we are driving home an extra car we are bringing and then will fly back to pick up the Z when it is done, so maybe we can meet up for lunch nearby the shop.
Quick Reply: [Z06] LS7 Wiggle Test DIY
