LS7 Spintron Testing Request and Donation Thread - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Z06 Discussion
General Z06 Corvette Discussion, LS7 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Closed Thread
Old 07-05-2014, 06:57 PM   #1
forg0tmypen
CF Senior Member
forg0tmypen's Avatar
Default LS7 Spintron Testing Request and Donation Thread
Official spintron testing donation thread for additional spintron testing done by Katech.
Rules:
Minimum $50 or greater donation to paypal address below
Donations are for spintron testing of combination #1 only at this time
Donations for more tests will be attempted once test #1 goal is reached
Goal to reach for test #1 is $900
Please designate who you are on Corvette forum when sending donation or designate "anonymous"
Testing results will be released only for those who donate
Combo #1 ($900) Reached!!
85g Ferrea SS hollow exhaust valves
torquer cam
PSI 1511 beehive springs/titanium retainers
Stock rockers
Combo #2
85g Ferrea SS hollow exhaust valves,
Stock cam,
Stock beehive springs/stock retainers,
Stock rockers
Combo #3
Stock exhaust valve,
Stock cam,
Stock springs,
HS roller tip rocker (provided by Michael_D)
Combo #4:
Stock rockers,
85g Hollow Ferrea exhaust valves,
Endurance cam (provided by Vert_C6),
Forum members who have contributed:
forg0tmypen- $50
Jasonoff- $100
VertC6- $50
Mark2009- $50
Beast5spdGTA- $100
Vray- $75, $125
MTPZ06- $50
Silvrhand- $100
Undy- $50
Michael_D- $200
LIT- $100
Wjnjr- $50
Pickleseimer- $50
Sled Driver- $50
Somgman3- $50
Bad_AX- $200
383- $50
Vette@71- $50
Coach62- $50
American Heritage- $100
7007vette- $50
RossN- $50
Nator02- $50
Wulverine- $100
Double06- $50
Daveng- $50
erick_e- $50
Mrkris- $75
Cerberus- $50
Total raised so far: $2,275!
Address to send parts for testing:
24324 Sorrentino Court
Clinton Twp., MI 48035
Official email address to send money to Paypal for dontations is:
spintrontestdonations@gmail.com
I have personally tested and sent the first donation of $50 from my personal account to this one. Please be careful typing in the email into paypal, and please, in the note section designate WHO YOU ARE ON CORVETTE FORUM. For example, see this screen shot of my donation:
forg0tmypen is offline
Old 07-06-2014, 12:46 AM   #2
vray
CF Senior Member
Support Corvetteforum!
vray's Avatar
Quote:
Originally Posted by forg0tmypen View Post
Who else would like to see the following tested on the spintron at Katech?:
torquer cam
beehive springs/titanium retainers?
Would think that would be a stable setup to appease those who dont like the stock exh valves and also those who are looking for a little extra piece of mind without sacrificing valve train stability at higher RPMs.
Given the thrashing by a select few CF members, I seriously doubt Katech will ever publicly publish results of their internal testing.
vray is offline
Old 07-06-2014, 01:19 AM   #3
richie427
CF Senior Member
torquer cam
That all depends on/ how many track runs/ 1/8.1/4 your dump an run/rpm hell i ant TECH, S4IT I cant even type, all i might, think i may no now allways changes, the game was built by gm 4 u 2 take it that much past the Z06 a workin man /gal can pay out .Like they say the ocean is sometimes blue, how much testthing are u willing 2 spend
richie427 is offline
Old 07-06-2014, 07:27 AM   #4
Z06Ronald
CF Senior Member
Z06Ronald's Avatar
Quote:
Fortunately Katech did publish results of the spintron tests. Follow the link in this post: http://forums.corvetteforum.com/1586941710-post50.html
I remember the thrashing very well, it was truly embarrassing.
Z06Ronald is offline
Old 07-06-2014, 09:26 AM   #5
Frankie2blue
CF Senior Member
Frankie2blue's Avatar
I would still like to see the fix using all OEM parts as designed. More than anything that is what I would have liked to hear from GM. Even If it took buying a new set of heads from GM, but as we know that's not an option because they are not proven yet as being "fixed" on the latest models. Only time will tell. I have been considering Katech because it appears that they are one to use the OEM parts. I am just trying to bide time to see how any of those jobs they have done work out, especially for the ones being driven hard.
Frankie2blue is offline
Old 07-06-2014, 10:03 AM   #6
forg0tmypen
CF Senior Member
Quote:
This combo is as close to OEM as you can get weight wise with a SS valve. There isn't going to be a revision to the OEM setup ever again since the motor is close to being out of production when Camero Z28 halts production. There's a lot of parts out there that aren't OEM and can't be OEM if you're running a cam like the torquer. Good luck with OEM springs and a cam. This is a combo really meant for those with a cam. If you want to see the Ferrea hollow valves run with stock cam and springs then that is a option.
Old 07-06-2014, 12:41 PM   #7
Sled Driver
CF Member
the last thread turned into such a sh*tshow i would be shocked if they ever publish results again
too many armchair mechanics and conspiracy theorists and big egos here at CF to allow for real, deep technical discussion
Sled Driver is offline
Old 07-06-2014, 12:52 PM   #8
fendersceptre
CF Member
Quote:
What??
fendersceptre is offline
Old 07-06-2014, 01:13 PM   #9
Vette @ 71
CF Senior Member
Similar member who trashed and ridiculed John G's thread on his extensive analysis and testing in determining geometry played a significant role in guide wear. As a result, John essentially quit posting although he has helped some members who have asked him for assistance..
Vette @ 71 is online now
Old 07-06-2014, 01:27 PM   #10
Michael_D
CF Senior Member
Michael_D's Avatar
Takes a lot of work and money to set up a LS7 test mule for the spin rig. From a business perspective, there needs to be payback for the testing costs. The payback would need to be in the form of testing something that the business either sells, or to validated a service they provide. Katech is a business, not a charitable organization.
Another option, is to just pay them to test whatever you want. This would probably be the best option, as you could specify exactly what you want tested; but it would not be cheap. One could potentially set up a "project fund", that interested persons could buy into. The interested persons could specify the combination of parts they want to test, and pay their portion of the testing fees, plus supply test components.
I like the second option. If there were others interested in doing something like that, I could take the idea to Katech, to see what it would take to set it up. I would suspect the buy in would be about $500 per person, and there would most likely need to be a minimum of $5000 for Katech to even consider doing something like this.
Michael_D is offline
Old 07-06-2014, 02:12 PM   #11
glenB
CF Senior Member
St. Jude Donor '08-'09 & '12, '14
glenB's Avatar
I think if forg0tmypen was willing to foot the bill and publish the report, anything is possible.
glenB is offline
Old 07-06-2014, 04:08 PM   #12
forg0tmypen
CF Senior Member
Quote:
Really wish I could. :/
Old 07-06-2014, 07:12 PM   #13
vertC6
CF Senior Member
vertC6's Avatar
I'll donate $40
vertC6 is offline
Old 07-07-2014, 09:51 AM   #14
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Spintron is $100/hr. One simple test will be way less than $5000.
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Inc.
http://www.youtube.com/katechperformance
http://www.facebook.com/KatechPerformance
http://www.facebook.com/KatechJason
Instagram @Katech_Inc
Twitter @KatechInc
Katech_Jason is offline
Old 07-07-2014, 10:14 AM   #15
MTIRC6Z
CF Senior Member
Quote:
Yes such a shame on both occasions.
I spoke to John G at some length a couple times, the guy knows what he's talking about and has an amazing amount of experience specifically measuring LS7 heads. Fortunately I have still been able to tap into that knowledge.
Unfortunately for the forum they have lost John's knowledge, experience and contributions, but just think, the forum has an extensive counting of SS valves to compensate
Cheers, Paul.
MTIRC6Z is offline
Old 07-07-2014, 10:21 AM   #16
Hib Halverson
CF Senior Member
I don't understand why anyone wants to go to the expense of spin testing the dry, hollow stem, exhaust.
The stocker weighs in the mid 70-gram area. An 85-g valve is going to need more spring pressure or a change in the cam profile to control–maybe not much of a change–but the difference could be enough to push valve motion to the limits of stability at the engine's rev limit.
Another issue I question about hollow-stem valves with no sodium in them. Whether the valve stem is metal, hollow-with-no-sodium or hollow-with-sodium filling, the stem is still the heat path from the valve head to the guide, to the head and then to the coolant.
With an "unfilled" or "dry" hollow stem valve, you replace metal with air which is a very poor conductor of heat compared to metal, so without sodium in the hollow stem, what are you doing to prevent the valve head from overheating?
Hib Halverson is offline
Old 07-07-2014, 10:50 AM   #17
propain
CF Senior Member
St. Jude Donor '14
propain's Avatar
Quote:
If you interested Jason I am sure people would be willing to donate to see some others tests get done.
Since the members would be footing the bill I would also hope the thread would be kept as clean as possible by the mods.
propain is offline
Old 07-07-2014, 11:57 AM   #18
Michael_D
CF Senior Member
Michael_D's Avatar
Ya, I was figuring about that much (hourly rate for the spin rig). Does that include the set up costs for the LS7 test engine? Maybe you could line out the total costs?
I suspect that there will be numerous combinations of testing that members would want to see. IE: rockers, different valves, with different springs, with different cam shafts. I'm guessing about three days worth of testing different combinations. Maybe more.
I was serious. If there are enough members curious enough to pony up some money to have their stuff tested, I'll coordinate it.
And no, $40 isn't even close to be enough. For that contribution, you MIGHT get to see the data.
Old 07-07-2014, 12:57 PM   #19
forg0tmypen
CF Senior Member
Jason how much would it be for the setup in the first post to be tested?
Old 07-08-2014, 07:56 PM   #20
jwebsta32
CF Senior Member
jwebsta32's Avatar
jwebsta32 is offline
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • LS7 Spintron Testing Request and Donation Thread
    Closed Thread
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Official St. Judes donation thread for Spintron Testing results forg0tmypen C6 Z06 Discussion 48 12-17-2014 09:08 PM
    PSI LS1511 Valve Springs, who's using them vertC6 C6 Z06 Discussion 24 05-21-2014 11:41 PM
    Accuracy of Spintron Test MarkC C6 Z06 Discussion 102 04-12-2014 02:20 PM
    Ferrea Competition Hollow Stem Valves. Thoughts? forg0tmypen C6 Z06 Discussion 98 11-23-2013 01:15 AM
    Who is running Katech single beehive springs with solid SS valves? forg0tmypen C6 Z06 Discussion 5 05-23-2013 10:01 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
