[Z06] Got bored with the red
I wanted to add my personal touch to this car, and since a vast majority of them have red brakes, a color change was in order.
New calipers, rotors, and pads. Calipers were powdercoated.
Needed this baby to get a couple of my wheels off
A couple good hits and this one came off
The before
Old brake pad vs. new brake pad
There was a good amount of pad life in the fronts but wanted everything new new new
It levitates
Unintentional Lakers Colors
Sore leg time
Need wider
The final
The before
It levitates
Sore leg time
Need wider
The final
Nice job. I like the color with black.
Only thing I'd say you need to never do again is get under the car when it's supported by a jack in the rear like that. Jack stands on all four corners. Always. I've lost friends when those jacks failed.
I did it with a friend, definitely a good learning experience, and some things I just wasn't physically strong enough to do haha except I was the one wielding Thor's hammer
Nice
Right Rear Inner
Right Rear Outer
Left Front Inner
Left Front Outer
Left Rear Inner
Left Rear Outer
Right Front Inner
Right Front Outer
Right Rear Outer
Left Front Inner
Left Front Outer
Left Rear Inner
Left Rear Outer
Right Front Inner
Right Front Outer
Looks great.
A power bleeder is great on these cars. Well worth the $80 or to borrow one.
install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve.
Install a transparent hose over the end of the bleeder valve, then repeat steps 7-11.
install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve.
Heh I liked the leg work out :P But will probably invest in a bleeder kit for the future. Unfortunately she is rocking 3 purple and one original red, since one of the purple ones was damaged A new one is on the way.
Props for changing out the color (although I wouldn't go that color) now how about more pics of you ?
Well done!
Well done!
