[Z06] how many miles on your WCCH
Unless they've had the guide clearance checked then those reports will be meaningless. A forum member had 88K miles on his stock heads, no apparent problems, but when he checked the clearance they were way out of spec.
"Running fine", "sounds good", "pulls good", "revs fine", "no apparent problems", without any measurements or inspection none of it means anything.
There are a lot of cars out there yesterday, which were "running fine", "sounded good", "pulled good", "revved fine", and had "no apparent problems", which either are not running today, or might not be running tomorrow.
Show me a car that popped in here, and more often than not, I'll show you a car that was "running fine", "sounded good", "pulled good", "revved fine", and had "no apparent problems", the day before.
Supporting Vendor
Received 1,012 Likes
Im all for this, we truly believe our guide is awesome and would love the opportunity to prove it to the community.
ps the longer guide is only used when you have seriouse concerns about heat... basically you don't think your material alone will solve your heat/guide wear issue so you lengthen the guide a little to help out. Its nothing new, used to do it back in the day on some SI engine that were pumping out 1200hp @ 45lbs of boost, the heat was just killing the exh guies, new material and longer guides fixed it. could have probably gone with just a better material but the shop I was working for at the time thought "same material we always use, just more of it" (i.e. longer guide).
and we would be happy to install both our PM guide, Bronze guide, OEM factory guide and even a new guide that we are having made just for us that will revolutionize the guide industry. they you can have the heads wiggle tested at an independent facility.
ps the longer guide is only used when you have seriouse concerns about heat... basically you don't think your material alone will solve your heat/guide wear issue so you lengthen the guide a little to help out. Its nothing new, used to do it back in the day on some SI engine that were pumping out 1200hp @ 45lbs of boost, the heat was just killing the exh guies, new material and longer guides fixed it. could have probably gone with just a better material but the shop I was working for at the time thought "same material we always use ( a slight variation of it), just more of it"
Out of respect, and it basically coming down to it being really nobody else's business, I certainly won't, and I sincerely hope that nobody else will, ask what shop that was.
The aftermarket bronze guide that the majority of rebuilders use may very well indeed be better than the factory's OEM PM guide. We recently sent a bunch of guides out to an independent facility to be tested. The Bronze guide was HRC25 (c scale,,,, this is in reference to how hard the metal is... lower number softer metal, higher number harder metal). We sent in a used oem gm ls7 guide that we knocked out of a head, it was HRC10 (c scale)... so in this case yes a bronze guide would be better than gm's oem pm guide. We also had our AHP aftermarket Hardened PM guided tested and it tested HRC40 (c scale). This would mean our hardened PM guide is harder than the factory's PM guide and harder than the aftermarkets bronze guide.
I'd bet shops that recommend OEM guides don't have this information. There should be another thread about this so this thread doesn't get off track.
My compromise with myself was if I wasn't going to buy a C7, I was going to buy a widebody C6 in LeMans Blue. I'd have been happy with a Grand Sport, if GM hadn't discontinued LeMans Blue in 2007. I suppose I could have had one repainted for $10k. I also could replace the LS7 in my Z06 with an LS3 for that and be done with this issue.
What I need is an aftermarket/machine shop head package that comes with a reasonable warranty against valvetrain failure. If GM can warranty a new LS7 for 100,000 miles with known bad valve guides, why can't these guys who are selling a "solution" provide a similar warranty?
The car has Kooks headers & Corsa exhaust. The seller said the first engine was replaced not under warranty (at 19,000 miles, in 2011), because the car had been discovered by GM to have been tuned. I don't have a lot of faith a warranty would cover me, and the car is well out of warranty now. I'd rather just spend $2k-$3k to definitively resolve the problem.
Once a year might be reasonable, if I can find someone who can do it locally - and it doesn't take an unreasonable amount of time.
Received 8,918 Likes
I'm going to have to agree with this.
Ran great until it didn't. Went from full throttle roar to Dead Silent except for tire and wind noise very quickly as coolant went through the intake to all the other cylinders.
Bill
Sorry guys, I'm an idiot. Wasn't thinking. Everything I read is just about stock heads. I just have stock heads with 16k miles on them. Please forgive me.
Dave
Dave
The 24hr race engine you keep speaking of is/was running a shaft mount roller rocker system (no real side loading of the valve). In this application Bronze is great. Bronze is not the best choice of valve guide material with a non roller tip rocker that causes lots of valve side loading.
The point being the harder the guide the more likely it is to resist valve side loading. In other words the harder the guide the less the guide will wear when exposed to high levels of valve side loading.
Theoretically a harder guide should wear less all around than a softer guide.
So application makes all the difference. Bronze with shaft mount roller rockers = good. Bronze with stock non roller tipped rockers = not the best material for the application.
Very informative but what's the downside to the much harder pm guide that you are currently using? Does the actual valve now take more of the wear and abuse? Or could these harder guides possibly create more heat in the guide ? If there's no downside why wouldn't other aftermarket cylinder head companies use these harder pm guides?
Thanks!
Thanks!
Thanks!
1. For the same reason they use dual springs -- they are locked in the past.
2. It takes some thought and effort to bring new items to the marketplace. It is also risky because, like many shops, many customers are . . . . . . . . . locked in the past
#33
Thanks!
Thanks!
Good point. I don't think its a hardness issue with the current PM guides. I don't think you would create any more heat issues however with the "harder" PM guides.
As well these guides have been in use for a very long time. As we all know as the years go by technology improves and its possible these guides that AH is using only recently became available. Aside from that even if they were available GM hasn't had guide issues up until this point. So why change something that's been working.
However, I do agree with AH and sticking with the PM guides would be best.
I am surely a mixed bag.... LOL. Ill take one order of PM guides from AH and One order of OEM valves and beehive springs. I appreciate all these vendors opinions but I want to stick as close to what the GM engineers had in mind as possible.
That is of course until I go beyond 650whp... then all bets are off.
#34
#35
well I bought a vengeance racing heads/ cam package and it better hold up for years to come ... guess I'll have to take my chance with the WCCH over AH for now. after this I'm doing a forged block with aftermarket heads, or buying a 2015+ Z when the time comes.
#36
No.
For two reasons:
For two reasons:
How do u know all these companies are stuck in the past. How do u know they are not using what works and has proven itself to hold up the longest to high horsepower builds?
P.S. Many duel springs have proven to work well and control valves on higher lift cams when over the years many beehive springs have proven to have durability issues. This is a fact.
I'm not saying the PSI Beehives aren't a excellent choice just that most don't have the great record they have earned.
#38
I agree with u. I don't think the OEM guides are the issue either. But maybe a harder guide would help slow down the wear or buy one more time.
#39
