[Z06] Guys running SS valves, what valve spring are you using?
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Would the concerns about heavier springs be mitigated by different springs (conical, beehive) and lighter retainers?
Look at the Katech testing. If you consider this current gospel then any spring selection isn't going to put you in much trouble with a stock cam. Relying solely on these examples it appears to me the PSI beehives dealt better than the duals in the cammed example and therefore should also be better with ss valves and the stock cam. However most of the fixes out there seem to be with duals and if there are failures related to this, we aren't hearing much about them. If you have to exceed redline to get real instability that is probably why.
[...] However most of the fixes out there seem to be with duals and if there are failures related to this, we aren't hearing much about them. [...]
There are several reported failures related to that -- spring failures (broken duals). But since it doesn't make the engine explode everyone seems to think it is normal, or at least 'okay'.
