[Z06] Almost dropped valve in my PRC heads
#102
Wow, got my LB motor from TSP with the the 265 heads but not milled, i think. But with the harden tips. as what you were saying in your first post. I am still waiting on parts, an money spent that i dont have, to get her on the road. ( NO THANKS TO GM)my TSP LB, is still sitting in my garage, Parts ordered so far from Maryland Speed are: kooks headers, halltech 103, tr6 plugs, slp 160 stat. fast 102, fast oem fuel rails, an ss hardware. OEM engine oil cooler, Dont know if i should change out the oem clutch i just replaced, at 30000 mi, it has about 5000 miles on it now. Off hand what other things (be sides a f---in hole in my head ) I should put into my 07 Z06.
#104
I think these specifics valves had issues, not all hardened tip Ti valves that TSP ever used. From what I understand they've used several different brands of Ti valves over the years.
#106
I was assembling a long block for my buddy and when I was about to install the head (used from his last set up) I noticed one of his intake valves looked like the one at the beginning of this post. I then decided to take a look at mine and while they arent as bad they are showing signs of wear. I guess I just noticed it before it got bad.
#107
Bump from the dead but wanted to see if anyone had this happen with there PRC heads, I'm debating on getting a new one from them or moving on to a different company seeing as there has been some issues with them dropping valves. I'd like to figure out why this happened before I move to the next step. Piston to valve clearance was right around .110 for the intake when installed. Stock redline.
drewz06 (02-28-2021)
#109
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
So, who was the 'expert' who installed the heads without the lash caps on the titanium valves ?
I remember seeing another thread here where the same thing happened to someone else with titanium valves and no lash caps ... lots of damage to that poor LS7
#110
I checked that all lash caps were on prior to installing the rockers and all the other valves still have there lash caps in place. No signs of wear at the top of the valve and retainer was still in good condition
#112
thing knower
ls7 or ls9
#113
Personally I think this is a poor design. The load bearing surface (in compression) of the titanium valve stem is greatly reduced when it is counterbored for the knurled portion of the insert. Then even if machining tolerances are held to tight tolerances pressing the insert into the weakened stem could cause micro fractures in the titanium. Then the side loading (or shear) capacity is also reduced because it relies on the smaller diameter of the knurled section of the insert. Compare this to the GM design. Combine this with high open spring pressures and non roller tip rockers and I think durability goes down.
#114
For what it's worth ...
I think the real fix for all these LS7 valve problems would be to install quality SS hollow stem intake valves and SS solid stem exhaust valves once the valve guides were machined concentric with the valve seat.
Just my opinion ...
Just my opinion ...
#115
Bow-Tie Guy
Next, which spring & then which lifter?
#116
