[Z06] Z-06 Emblems For those who "Stock" wasn't enough...
They look OEM quality
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
One thing, the emblems are not coated and from time to time will require some aluminum polish touch-up. I talked to Austin about this and he said he had problems with coating them that didn't yield good results.
I talked to Austin specifically about this. Polished aluminum is the ONLY option. He was adament about that. He said he'd tried coatings and he didn't like the results.
BTW... these emblems aren't his main hustle (as was mentioneded before) and he said he will stop making these in the not-so-distant future. I'm actually a bit surprised that GM hasn't shut him down for copywrite infringement. They've done it before on similar situations.
They are very nice I have the 625 hp set
I will need to update (700 hp) so I will be selling mine so if interested PM me.
I installed them today. These are the steps I used.
1) Put 2 pieces piece of masking tape on the paint, vertically and against the front and rear of the emblem. Mark touch points with a sharpie between the emblem and the masking tape to enable correct location/installation of the new emblems.
2) Use a heat gun or hair drier to heat up the old emblems. Get them real hot and don't fry the paint.
3) Use a light weight fishing line and "saw" between the emblem and the body immediately after heating. You might have to reheat several times to get through it. Note: Dental floss was mentioned before. I tried and it didn't work. Friggin' floss kept breaking.
4) Rub as much of the existing adhesive off with your clean fingers. I used brake clean as a solvent. It took a lot of rubbing to get all the residue off. Other solvents may work better but I was paranoid about experimenting and damaging my paint finish.
5) Line the new emblem up with previous sharpie marks on the masking tape then peel 'n stick.
