[Z06] Think we could run P Zero Corsas on the Z?
I keep hearing how great the P Zero Corsa is making the Camaro Z28 and wonder if anyone has tried them on the Z?
Maybe the right sizes are just out (or maybe not yet) but the 295/30/18 up front should work. A bit wider but shorter than the 285/35/18 PSSs I run. In the back may be the problem. I am running 345/30/19 PSSs with no fitment issues or rubbing. But the Corsa only comes close in needed sizing with a 355/30/19 size. That may be asking too much.
The other challenge may be stagger. The front Corsa would be 25" and the rear would be 27.4". This is versus the 25.9" front PSS I am running and the 27.2" rear. The greater stagger may be too much for the Nanny's.
Any experience would me most helpful.
These have a lifespan comparable to the Pilot Sport Cups. If you're replacing MPSS, you're going to be disappointed with the mileage you get from them.
And that's if you just ignore the size problem.
But for your information, they do make a 285/35/18:
http://www.tirerack.com/tires/tires....R8P0&tab=Sizes
