[Z06] Get the Best High Performance Engine & Trans Mounts On the Market @ Hinson Motorsport
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Chris, thanks, i got your email with your explanation and trying to sort things out with USPS. A friend from the US was trying to get intouch with you and he couldnt. No Worries. Will update you when i receive the shipment. Keep up the good work and support.
Your very welcome. Im sorry for any difficulties you or your friend had, but hopefully everything is worked out now. Thank you fro your business and understanding. Let me know if there is anything else I can do to help.
On the C6 there is no reason to run a short unless you need extra hood clearance for a turbo or supercharger. There is no vibration difference between the two.
