[Z06] Get the Best High Performance Engine & Trans Mounts On the Market @ Hinson Motorsport
Former Vendor
Urethane Engine & Transmission Mounts for the Corvette C5/C6
MADE IN THE USA!!!
These urethane engine mounts are designed for a great balance between engine control and vibrations. They have been tuned for both street and track applications. Replace your stock rubber mounts for improved throttle response and reduced engine movement.
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Applications
* 1997-2013 Corvette C5/C6/Z06
Urethane Engine Mounts Standard Height C5/C6 Click for Pricing
OEM Standard Height
Urethane Engine Mounts (Shorter Version) C5/C6 Click for Pricing
.360" Shorter
Also Available in Engine & Transmission Combo Packs
Urethane Engine & Transmission Mount C5 Combo Pack Click for Pricing
Urethane Engine & Transmission Mount C6 Combo Pack Click for Pricing
*Want to become a dealer for these items??? Email chris@hinsonmotorsports.com
Why Are They So Much Better?
As you can see in the below cut away image, the engine rides on the durable urethane. This is how we control engine movement while not passing every vibration in to the passenger compartment. The inside of the mount is interlocked. Even if you found a way to damage the mount, the stainless interlocking design will keep it all together. The design is built with stainless steel, so they will not rust. They accept your factory nuts. This means there will be no emergency hardware store trips.
Former Vendor
No modifications needed, and straight forward install. Don't forget about our Hinson Motorsports Engine Mounts in the Shorter Height for extra hood clearance and a lower center of gravity for the engine. Buy them in Combos to save even more money.
Former Vendor
motor mounts
Allthough my stock motor mounts were fine, decided to give this mod a try. down side- a little more NVH- very little, in fact after driving for 2 days I don't notice it any more. Plus side- car feels tighter, the shifter works wayyyy better, and much improved throttle response. I would give this an 8 out of 10 mod. if you have broken motor mounts 10-10!
Former Vendor
Former Vendor
Former Vendor
We love the feedback guys and really appreciate it. We worked hard to design and build a cost effective mounting system that would withstand the abuse that everyone threw at them. We are very proud to bring these to the market and the feedback that we get from you telling us how well they work is very rewarding of a lot of hard work. Thank you all for the business we do value it and appreciate it.
Former Vendor
Are you guys still open for business?
Hi
You sent my mounts over ten days ago but it seems either someone from your side or the post office put the wrong country code and now my shipment is in New Zealand. Been there since the 2nd i believe. i tried emailing you and IM'd you but nothing. Order number 106228. Also, tried to find a working number for you guys but all out of commission.
Former Vendor
Hi
I got your notification on Monday and replied via email yesterday with detailed information that I received from USPS. We shipped the items to the address you provided on our website at the time of purchase. I personally spent over 45min on the phone tracking your package and arranging the package to be forwarded to you from New Zealand where it is in customs currently, so you were not out any more time due to shipping. I am unclear as to the troubles you were experiencing from trying to call as our working number is posted in the banner at the top of this thread as well as in the signature of every post I make, along with my personal email address that also has all of the contact information in the signature. We value your business and are doing everything we can to correct a problem that has occurred by USPS and even provided you with all the tracking information, case numbers, and forwarding information that I will gladly email to you again. Again I do apologize for the delay in shipping but to be clear this was an error on USPS not us and we are making every effort possible to ensure you receive your parts.
Chris, thanks, i got your email with your explanation and trying to sort things out with USPS. A friend from the US was trying to get intouch with you and he couldnt. No Worries. Will update you when i receive the shipment. Keep up the good work and support.
Sir,
