[Z06] Hinson Motorsports 1000HP Aluminum Driveshaft & Couplers for Your Corvette
Former Vendor
3.5" Aluminum Driveshaft for 01-13 C5, C6, & Z06 Models
Hinson Motorsports has partnered with Precision Shaft Technologies again to bring you another fantastic product for your Corvette. This all aluminum 3.5" driveshaft is a direct fit application for all 2001-2013 Corvettes. With a 1000HP rating it makes a great addition to high horsepower car. For additional strength don't forget to add our billet aluminum couplers to each end.
Billet Aluminum Couplers
Former Vendor
Grab yours today while the Hinson Motorsports Promotion Last. This set up was torque tested at 1200 ft/lbs of torque and didn't even flinch. Buy with confidence it will take the beating you can throw at it.
We just installed this setup with the billet couplers and while it does feel stiffer/rigid it also has a little more driveline noise so if you are removing the rubber couplers then be aware that solid does come with a little more noise, it does feel nice no doubt!!!!
Former Vendor
Great feedback that is spot on. While it does make the driveline a little more noisy, you have the security of knowing you dont have to rely on those rubber couplers and all the sponginess that comes with them. Plus you can beat on the driveline and not worry about anything giving way to all the punishment. Thank you again for the business and the great feedback.
