[Z06] Strange / Interesting steering feel
I have noticed, at very slow speeds / engine RPM (think first gear in heavy traffic) that when moving the wheel back and forth, say 2 or 3 inches of travel, I feel a slight "stiction" in the wheel (if you know what that is relative to suspension smoothness, you'll understand) when transitioning back and forth, and I can "feel" / hear the pump working as well..
It seems to go away / diminish at higher speeds / engine RPM.
I don't necessary suspect anything is "broken", but my old C5 never did this, and my 2011 Z06 is the only C6 Z I've driven. It also has the ZR-1 wheel and tire setup.
For those that are interested to see if their cars behave similarly, make sure the radio is off, slow speed in first (basically at engine idle) and slowly saw the wheel back and forth, feeling and listening for the stiction / pump noise.
I am wondering if it is part of the slow speed behavior / pressure valve programming in the BCM..
Thoughts? -ds-
Thoughts? -ds-
This is the small stuff you notice while stuck in traffic. Doing hot laps on a racetrack, you'd be preoccupied with other things.
Wondering if it has to do with the pump turning at low RPMs..
Then you could actually have a problem. Sorry.
Thoughts? -ds-
Thoughts? -ds-
Later C6 vettes including Z06s, ZR1s, Grandsports, etc. have a magna steering rack that has a design issue. Magnet shift in the rack causing what you are experiencing. GM is aware of the issue, but as I understand it they don't have a fix yet. They will replace the rack under warranty, but the new rack is also prone to this failure.
I've read of that also... you'll have to dig around/search, the info is out there. Google will probably work better than CF search function.
From what I've read before, the biggest 'hitch' you'll feel is right at 12:00 on the wheel position (as it passes thru that). IIRC . . . .
Ok, I found the thread, and from the problem description, I don't believe I have a failed rack.. No "clunk" at all, and I have to do several slow / rolling lock-to-lock turns to get out of my garage.. What I am feeling is much more subtle than what was described in the failing rack thread, to the point that a large majority of folks might respond with "I don't know what you are going on about.."
The just seems to be the tiniest extra "break-away" resistance in the feel when going slow / low RPM's. Now that I understand the issue reported in the failing rack thread, I will see if I notice this at a different position of the wheel, maybe turned a full rotation to the right, then move it back and forth, see if it is the same or not.
It is entirely possible this is simply a case of "it's just how a 2011 C6 steering rack feels with giant front tires to a detail-oriented person".
