[Z06] Bolt ons+heads with stock cam?
I am in the market for a C6z, and would most likely get an 08+, I would use the car for mainly street and daily it. I know about the valve dropping issues that the LS7 has. The idea would be to get a stealth car that appears and sounds like a bolt on car that has good power. So I do not really get a cam, or pick a cam that has NO lope and any LS head wont be able to tell if the car has a cam. So basically get a full bolt on car with ported and milled heads, so how much power would a full bolt on/milled heads car put down?
490-500 rwhp with a good tune. By bolt-ons, you including full exhaust?
i have a 08 and with vararam intake ported polished stock TB and FAST manifold with kooks catted headers stock axle back and IPS stage 2 head work no milling heads were done when i bought the car i put down 490rwh 485rwtg on a mustang dyno car ran 2 consistant 158 mph passes in the chicago half mile event this summer which is what the cammed cars were doing have not had it to the 1/4 yet hopefully friday expecting 10.8-11.0s at 130mph
The car did 525Rwhp and 480RWTQ on a very hot and humid day. So seems like a good combination if you are keeping stock cam. I feel like the milled heads were probably good for 20-25hp.
I just had my heads reworked with ferrea hollow stem valves in my 08, I did .030 milled heads, did LG 1 3/4 headers, Haltech KillerBee intake, PSI springs and a tune.
this seems pretty stock sounding to me considering it is cammed and making 560 whp.
and whats the point of trying to have a "sleeper" Z06? why not just throw a ECS kit and leave the stock manifolds/exhaust? most that I heard are pretty quite and obviously a lot more powerful than most head+exhaust Z06s trying to make miracles to happen. Either the person you are going to run will run regardless of how your car sounds.
Darin Morgan ported heads, milled about .030. I have Fast w/102TB, Longtubes with cats, Akro axle back, Halltech CAI, ATI balancer. Stock Cam
Car made 507hp/490tq on a conservative dynojet. (Prior to tuning, I had same setup on another dyno, made 499rwhp. First pull on the dyno I tuned on it with numbers above it was 484rwhp) Figure that 15 HP difference and that puts it right with the guy above with similar setup.
But figure 500-530 rwhp dyno and tune dependent. Every Dyno and day is a little different. Hard to realistically compare numbers
Contact Carlos at vette air. I am sure he can get you into the 550+ range with some nice head work and high compression + e85 and full boltons. He is by far your best shot on the forums...
sleep st4.MTS - YouTube
