[Z06] Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZO6 LS7
Former Vendor
St. Jude Donor '13
Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZO6 LS7 (C6)
Rebuildable, Lightweight Clutch
Holds 1400 HP & 1000 Ft/Lb TQ,
While Offering Stock-Like Pedal Feel
Quarter Master®, the industry leader in driveline technology, has continued its winning ways with Optimum-SR™ 10.4" Two-Disc LS Clutches. They have achieved standout results with a Camaro in the GRAND-AM Continental Tire Sports Car Challenge Series, including a first and second-place sweep at the Indianapolis Motor Speedway. Now, with lessons learned from racing, and with the data from extensive drivability testing, Optimum-SR™ LS Clutches are available for street use.
Features a spring designed to require only a 10 percent increase in pedal effort over stock, with stock-type modulation control. The clutches are capable of handling 1400 horsepower and 1000 ft.-lbs. of torque. Features a sprung hub, marcel-type discs with organic rag-type friction for smooth engagement. A vented floater plate and grooved friction surfaces provide better cooling as well. Featuring aircraft-grade bolts and hardware with an all-billet construction, each clutch is completely rebuildable and can be used with OE hydraulic bearing systems or Quarter Master® Tri-Lite II Hydraulic Release Bearings.
1400 HP & 1000 Ft/Lb-Capable
Near Stock Pedal Feel/Power Modulation
CNC Billet Design Is Easily Rebuildable
Lighter Than Stock Clutch
Compatible with OE hydraulic bearing systems or Quarter Master® Tri-Lite II Hydraulic Release Bearings
https://www.xplosiveperformance.com/...-V_p_3391.html
http://www.xplosiveperformance.com/T...ng_p_3684.html
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Complete setup Flywheel and all 43 lbs
#37
Former Vendor
St. Jude Donor '13
Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZR1 LS9 (C6)
Compatible with OE hydraulic bearing systems or Quarter Master® Tri-Lite II Hydraulic Release Bearings[/SIZE][/CENTER]
http://www.xplosiveperformance.com/Q...C6_p_3392.html
#38
Former Vendor
St. Jude Donor '13
