[Z06] Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZO6 LS7
#41
Former Vendor
St. Jude Donor '13
Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZR1 LS9 (C6)
Rebuildable, Lightweight Clutch
Holds 1400 HP & 1000 Ft/Lb TQ,
While Offering Stock-Like Pedal Feel
Quarter Master®, the industry leader in driveline technology, has continued its winning ways with Optimum-SR™ 10.4" Two-Disc LS Clutches. They have achieved standout results with a Camaro in the GRAND-AM Continental Tire Sports Car Challenge Series, including a first and second-place sweep at the Indianapolis Motor Speedway. Now, with lessons learned from racing, and with the data from extensive drivability testing, Optimum-SR™ LS Clutches are available for street use.
Features a spring designed to require only a 10 percent increase in pedal effort over stock, with stock-type modulation control. The clutches are capable of handling 1400 horsepower and 1000 ft.-lbs. of torque. Features a sprung hub, marcel-type discs with organic rag-type friction for smooth engagement. A vented floater plate and grooved friction surfaces provide better cooling as well. Featuring aircraft-grade bolts and hardware with an all-billet construction, each clutch is completely rebuildable and can be used with OE hydraulic bearing systems or Quarter Master® Tri-Lite II Hydraulic Release Bearings.
1400 HP & 1000 Ft/Lb-Capable
Near Stock Pedal Feel/Power Modulation
CNC Billet Design Is Easily Rebuildable
Lighter Than Stock Clutch
Compatible with OE hydraulic bearing systems or Quarter Master® Tri-Lite II Hydraulic Release Bearings
#43
Former Vendor
St. Jude Donor '13
Quarter Master Industries Optimum-SR 10.4" Two-Disc LS Clutch For Corvette ZO6 LS7 (C6)
https://www.xplosiveperformance.com/...-V_p_3391.html
http://www.xplosiveperformance.com/T...ng_p_3684.html
