[Z06] Z06 GM head Replacement ?
Can any one who have had there heads replaced at a GM dealer tell me if they received new heads from GM fully assembled or bare heads. With out valves or springs....I need to know ,,,Thanks Ellis
Pro Mechanic
With my warranty head replacement back in July, we got a set of bare heads and a bag of parts. I had my cylinder head service assemble them for the dealer, but...we also measured the heads and valves prior to assembly and found some valve seats with runout. It was more expedient to use my head guy's Serdi to repair those seats than to try and get another set of castings.
Supporting Vendor
Received 1,012 Likes
There is no GM part number for a loaded head (with valves and springs installed). The P/N is for the bare head alone then individual P/N's for each part. As stated by Hib, bare heads and a bag of parts.
GM Performance Parts offers a loaded head (12578449). I have read (here) of some dealers installing those, apparently with GM's blessing (under warranty).
Supporting Vendor
I stand corrected sir, thank you for the knowledge. I was under the impression gm p/n 12578450 was the only p/n for the ls7 head. Learn something new all the time.
Last edited by American Heritage; 09-18-2014 at 09:39 PM. Reason: spelling and left out a word
No, factory head bolts are TTY.
https://www.corvetteforum.com/forums...ggle-test.html
My heads replaced under warranty in Nov 13 were complete.
Received 8,915 Likes
Do you know the date code on your new heads? I am wondering if you happened to get a set of older heads out of stock. From what I have heard from software developers their service parts operation leaves a little to be desired when it comes to tracking part numbers.
Bill
St. Jude Donor '09-'11
My 09 Z heads were replaced under warranty at a Chevy dealership. Bare heads (12578450) with required parts for assembly. Dealer had a local machine shop assemble the heads, then back to the dealer for installation.
I tried calling them, but they didn't remember anything a year later. My concern is that my new heads could be just as messed up as the old ones like in Hib's case (and one other case mentioned on this forum.)
