[Z06] Looking to buy a used Z06, anything to watch out for?
I'm in the market to buy a used Z06 (looking at 2006 and 2007). I have a 2006 Z51 car right now so I'm somewhat familiar with the C6 platform. I'm also a pretty good wrench and replaced the harmonic balancer already as well as a few other suspension parts.
Besides the valve guides and sometimes finicky caliper guide pins is there anything else to look out for on a used car? I would assume the harmonic balancer issue on the Z51 cars is probably also an issue on the Z06, but maybe not. I freaking love the C6 Z06, but since I have a C6 already I'm not in a huge hurry to pull the trigger.
Thanks,
Steve
Thanks,
Steve
the whole engine. lol. dropped valves, cam wear, rod bearings, split blocks, just to name a few issues with the ls7. the rest of the car is mint id never use a z06 as a daily unless it had warranty so a newer model. i got one now but the engine is forged n blown and a weekend car
Stuff I had to have fixed on my 2006, within first 35,000 miles, that you ought to consider:
-Harmonic damper flew off
-Roof replacement
-Differential creak at low speed turns
-Shifter vibration/noise/harshness
-Loose rear axle nuts
-Crap valve guides
Otherwise, it has been a pretty decent car. All except valve guides/heads was done under warranty.
-Roof replacement
-Crap valve guides
I bought my 2007 Z new and now has 51,000 miles and my issues have been:
1. Leaking pan gasket (warranty fixed it)
2. Rattling shifter (warranty replaced it)
Steering wheel sensor, roof recall, axle nuts, hydralic/clutch issues, tire wear and alignment, carbon pad in stock intake, etc etc.
