[Z06] ARH 2" to 2 1/8" headers with 3.5" Hpipe, Vband connections, "Getting it done"
Premium Supporting Vendor
ARH Big Tube C6 ZO6 headers with H-pipe are now available for high horsepower Supercharged, Nitrous or N/A combinations producing 900 to 1500 RWHP. The system is designed for standard deck height engines.
Features include:
2” X 2-1/8” primaries with 3-1/2” merge collectors with V-Bands
3-1/2” H-pipe with V-Bands (Pictured)
Optional extended H-Pipe with reduction to adapt 3” Connection Pipes to rear axle (Direct Bolt-In Kit)
Fully Tig Welded Construction using all USA manufactured 304 S/S
Great Fit and Easy Installation
Will fit standard C6 with mild modifications
Built to handle whatever you can throw at it, this is the last system your high powered C6 ZO6 will ever need. Call us to discuss your needs and what this system can do for you.
Current lead time is 1 week, these were designed and will be built here at our World Class ARH manufacturing facility in Deer Park, NEW YORK.
Features include:
__________________
FIRST C7 IN THE 9's....ARH Equipped.
631-608-1986 ext. 101
Email: steve@americanracingheaders.com
Facebook: www.facebook.com/americanracingheaders
Web: www.AmericanRacingHeaders.com
USAF/OIF VETERAN
USAF/OIF VETERAN
Congrat's on being the FIRST header manufacturer to finally "get it" and offer a 3-1/2" merge collector for our beloved C6Z LS7!!! You should seriously consider this as an option for your 1-7/8" stepped headers (since that's where the bulk of your market is and where you'll make the most $$$) and at least offer them as a custom option...just a thought to once again stay "Industry Leading" and watch the competition follow
D-port matching headers are a myth and round makes more power!
I'm wondering why not made them D port anymore.
LS7 heads are D port.
[QUOTE=JMB;1587976443]Congrat's on being the FIRST header manufacturer to finally "get it" and offer a 3-1/2" merge collector for our beloved C6Z LS7!!! You should seriously consider this as an option for your 1-7/8" stepped headers (since that's where the bulk of your market is and where you'll make the most $$$) and at least offer them as a custom option...just a thought to once again stay "Industry Leading" and watch the competition follow
Looking nice!!!
You're out in Deer Park? Use to waste alot of gas up and down Route 231 back in the day.
Some good times back then.
Congrats with the new Headers. Will be interested to see how much more they allow in a 1/1 swap, and then how much more tuned.
Nick
A.R. Headers
Seb, We were the first to use D-port flanges for the LS7 cylinder head back in January 2006. When we first released 2" headers we went with D-port flanges but we knew it wasn't necessary based on what we've learned thru testing with a variety of applications. Not blocking the port is what is most critical. Your typical 1-7/8" round LS1 flange may block the port which prompted us to offer the raised D-port flange. There is absolutely nothing wrong with running 2" round port flanges on LS7 heads. There is no power disadvantage whatsoever. Hope that clears things up.
Nick
A.R. Headers
Nick
A.R. Headers
We've listened to feedback and testing from numerous high level sources in Michigan.
With was a flowing close to 400cfm or more..
Ask them what size header they wools recommend.
The headers posted here are a lot closer to that recommendation than anything else on the market.
Especially when compared to the stuff
Most of us run.
These headers look killer. Don't underestimate how important the right set of headers are. Great job ARH.
I have a stepped header system built by ARH made for my 396ci 1000fwhp race motor and they working great on my 346 ci 470whp SBE ls6 motor.
