[Z06] The "Who did your heads Registry".
#201
My questions are out of thousands Z06s that were made:
1.how many actually dropped valve?
2.How many actually had valve guide issue?
3. Can you hear a noise that is distinguishable from before or it just drops out of the blue?
4.If it didn't break by 35000 miles, what is the likelihood of it breaking after?
5. Did people drop valve if they never drove it hard?
Inspect your car, examine the results, take action based on those results. That's the best advice I can give you. Lots of good options for resolving valvetrain issues that plague these cars for very little money when compared to cost of ownership (clutch, tires, brakes, etc.). By no means should this issue deter you from purchasing one of these cars if its really what you want.
#202
.....on the money....!!!
No amount of data/statistics is going to get you the answer you're looking for. I assume you're either looking to buy, or have just purchased a C6Z? The only way to know if you own a car that's adversely affected, is to inspect your own two cylinder heads. Don't get caught up in a numbers game, and try to justify why you should or shouldn't have to fix something that hasn't even been inspected yet...and its a simple process to do so.
MTPZ06 (01-26-2017)
#204
Sure you can.......
If you take both rockers off one cylinder like #1, then perhaps #4 and if you look very closely at the part of the valve stem you can see, just push, or rock the top of the spring retainer or top of the valve intake to exhaust or exhaust to intake and look and feel for movement......It is NOT as good as taking it apart by any stretch.... but if you feel movement it would be prudent to take it to someone for the real check out......Mine were so bad after I did the complete check and teardown (spring off) with compressed air, I found I could tell just by pushing on the top and watching very closely....The stem seal will just push up and you can see the stem move in the guide with good lighting.....just push with your hand. Needless to say I completely redid my heads......Just doing this is a good start to seeing how much where you may or may not have....It's a start.....good luck.....
Triple88a (01-31-2017)
#205
Allow me to post the results of my 'wiggle test', performed by Kohle at AHP.
2006 Z06 that I purchased after it had the motor replaced by GM. Current engine had approximately 5k miles on it. I had the initial check of the heads done at LG while they were still in Plano. The findings were poor, so the heads were taken off and sent to Kohle.
Results:
#1 int .020" #2 int .013"
#1 exh .007" #2 exh .007"
#3 int .015" #4 int .015"
#3 exh .0075" #4 exh .006"
#5 int .012" #6 int .017"
#5 exh .007" #6 exh .0065"
#7 int .018" #8 int .019"
#7 exh .009" #8 exh .0065"
Replaced with:
AHP Package 4
Ported heads
BTR dual springs with titanium retainers
BTR stage 3 cam
This was all done a while back and I recently sold the car, so if you've purchased a velocity yellow Z06 in the DFW area in the last few months feel free to contact me. I have some invoices for it and such.
Results:
Replaced with:
AHP Package 4
Ported heads
BTR stage 3 cam
MTPZ06 (02-05-2017)
#207
American Heritage Performance did the heads on my 2007. Replaced the Ti intake valves with OEM replacements and Ferrera Exhausts. PM guides, CHE trunions and Johnson lifters. Everything else is stock.
The heads were done at 29,000 and I am now at 31,000. I run 0w-40 mobile 1 and deleted the oil cooler. So far, so good and the valve train is much quieter.
#210
Formula8 (07-19-2019)
#211
Cordes Perfomance Racing (Phoenix)
Mileage 62,000
Material WCCH Heads
Parts Custom Tune
Car used for....In town and long drives no track
Cam OEM
Follow up disassembly and data. +65 HP on Dyno
Oil change intervals...4-6,000 miles
Type of oil Mobil 1 (OEM)
Mileage 62,000
Material WCCH Heads
Parts Custom Tune
Cam OEM
#214
Premium Supporting Vendor
Our specs are the same as GM. The production tolerance is .001-.0024" on the intake and .001-.0026" on the exhaust. The service limit is .0037" on the intake and exhaust.
Formula8 (10-30-2019)
#216
