[Z06] The "Who did your heads Registry".
Warranty repair at Parkway Chevrolet, Tomball, TX
Mileage: '09 model, 16,000mi @ repair June '13
Parts: New stock heads & valves blueprinted and assembled at G&G performance engines. Heads installed at Parkway.
Car used for: Mainly country roads in TX and Mexico, some around town and road trips, no track.
Cam: Stock
Oil change intervals: 3000mi
Type of oil: M1 5w-30 prior to repair, 0w-40 after
Current mileage: 22,000
So far, so good....
Cam: Stock
So far, so good....
I was about to request it, and offer to pay if necessary, but I didn't have to. That's where they send their LS (and now LT) machine and assembly work. Covered under warranty.
Very good experience overall. PM me for more info.
07 z06
.008 exhaust wiggle at 21k miles
Warranty replacement all new 2013 OEM heads and valves. Now at
27k miles, not retested; under ext gmpp warranty till 2017. Head work done at local machine shop and car reassembled by Al Serra Chevrolet.
Car is all stock.
Dam I love this car!
Car is all stock.
Abel Chevrolet
41K then, 46K now
new oem heads, old hardware
track days and mostly freeway miles
stock cam
oil changes at 50%
mobil 1 5-30
follow up will be in 2017 just before gmpp expires
41K then, 46K now
stock cam
oil changes at 50%
mobil 1 5-30
Who did them: HorsePower Addicts (HPA)
Mileage: 18k, now has 20K miles
Material/Parts: No porting, Ti intake valves, stainless exhaust valves, new bronze guides, BTR Platinum dual spring/Ti retainers
Car used for: Street car with occasional trips to the 1/4 mile
Cam: Katech Torquer 110
Oil change intervals: 2-3k miles
Type of oil: Mobil 1 5W30
As you know my last car had WCCH StageII, stock cam, M1 0w40, 20K+ miles, changed oil every 3-5K miles, many track days, passd wiggle test, all was good but found a wall at track
Right now new car is completely stock with warranty. I look forward to your testing and conclusions as I'm sure they will be interesting and I will consider them when the time comes for WCCH to upgrade my heads again.
DH
DH
Didn't get to keep heads or anything else. Car never made it back to my house after hitting the wall. Sold it to CMS within a week. New car is completely stock with 4yr warranty.
DH
-Vengeance Racing
- WCCH Stage 2, SS Exhaust valves, Bronze guides, Dual Springs/Ti Retainers
- Stock Cam
- Street driving + ~3 HPDE/yr
- M1 0W-40
- Oil change prior to HPDE event
- Stock Cam
- M1 0W-40
#33
Who--Complete Street Performance in West Chester Pa.
Mileage---29,000 then---32,000 now
Parts---Advanced Induction rebuilt and ported my stock heads.
Bronze guides
Kooks headers
Manley Nextek .700" Dual Spring Kit
Ferra—hollow core exhaust valves
Lunati Signature Pro-Series Linkbar Lifters
Lunati “Vodo series” Camshaft---Duration--223in—235ex. Lift--.615in---.626ex.
LS7 Airdaid Intake System
Results---560hp---515trq
Car used for---2 or 3 HPDE's per year. Other than that abusive washing and waxing.
Oil change--- 4 thousand or just before HPDE
Oil type---after build--0/40 mobile 1 European blend
Bronze guides
Kooks headers
#35
Stealing JShort's format.
Who did them: G&G Performance Engines, Tomball, TX
Mileage: 29k, now has 32K miles
Material/Parts: Stock Ti intake valves, Ferrea Competition Hollow Stem exhaust valves, new bronze guides, Katech PSI Springs with Ti retainers, Morel Pro-series lifters
Car used for: Street car with occasional trips to the 1/4 mile (and eventually local road courses)
Cam: Lethal Racing "Phantom"
Oil change intervals: ~4-5k miles
Type of oil: Redline 5W-30
#36
Work done by.....Ragin Racin
Miliage.....30K when work done. Pro active(exhuaust valves)..nothing was wrong with the motor that I knew of. Did not have the guides check before rebuild.
Materials....heads ported..solid Ferrea exh valves. A Stage 4 build, so the heads have all the goodies. Installed ARP studs, Crane lifters, Comp Cam trunion upgrade.
Cam....Stalker..551/501
Oil change....once a year..usually about 3k miles.
Oil type....usually Mobil 1 5-30, but will use other full syn oils if I catch them on sell. Ragin Racin put Redline in it.
Use...just tooling around..once a year to the drags.
A couple of thousand miles since build....everything is great.
#38
- Vengeance Racing
- Done at 18,000 now have 28,000
- WCCH Stage 2, Ti intake, SS Exhaust valves, Bronze guides, stock springs
- Stock Cam
- Occasional 1/4 mile. Mostly street.
- oil change at about 20% life left.
- M1 5w-30
- Stock Cam
- M1 5w-30
#39
Too-Fast - I also had my car in Katy at Bumbera's and I want to say the name "G&G" for doing my head work came out.... He kept referring to a guy named JOE? Does this sound correct?
anyway:
HeadWork - Factory heads, re-worked with new Valves, guides, springs, etc by G&G and installed by Bumbera's.
54K Miles on the car
Cruising the Streets with some blips of the throttle.
Running Mobil 1 oil.
anyway:
#40
St. Jude Donor '10-'11-'12
Material-stock heads
Parts -WCCH milled for 11.5: 1 CR
Car used for.... highway/ street terror
Cam - 21st Century Muscle Cars: 240/248, .644/.651, 114 LSA
N2O to come
