[Z06] What is this (Cam Question)
So this is what I am thinking.
"Inspect the lifter rollers for cleanliness and for smooth operation. If chatter marks are found on the rollers, this is a sign that the lifter bearing may have been sticking, in which case the camshaft should also be inspected. If chatter marks are found on either the lifter roller or the cam lobe, replace the errant component."
How do I get to the lifters? I know it is a dumb question but I have never messed with lifters before.
Summit Racing® LS Lifter and Guide Kits SUM-HTLSKIT.... thoughts?
The heads have to come off to get the lifters out.
Replace them all. Last thing you want is to have another go bad and have to re do the heads and cam because you wanted to save $100 on lifters.
Might want to put new trays in at the same time. They are cheap as well.
No, don't run summit lifters IMO. Either new GM ls7, or a good aftermarket (morel, lunati, crane, BTR, etc).
Replace the trays for sure. Also run a better oil next time around.
