[Z06] Need to adjust arms tires wearing ??
I have a 06 z06 and I put more spacers on the top part of the arms..There were like 3 already.I think I need more. Tires are wearing on the inside a lot more then outside..Is there an adjustment for the lower arms?? Or just load up upper arms to make wear better?
The stock alignment for the Z06 is pretty aggressive (more for track). Take it to a good alignment shop and tell them you want a less aggressive alignment and tell them the insides are wearing much faster than the outer. I believe it's the toe-in that needs to be adjusted.
Yes lower rear arms are adjustable. Take it in for an alignment, which is something all owners should do. It makes a huge difference.
Received 8,930 Likes
Bill
ty all. I will look again for a lower adjustment point too bring it in a bit as I changes my tires.I did look for a lower spot and didn't seen anything that I thought might bring it in..Can I put more spacers on the top? There are 3 already..I do like the tire sticking out of the well more then inside the well that's why I have 345 wide tires. They should pay you guys for your help to so many..
Bill
I take it you are talking about the rear tires as you mention 345s. The lower control arm camber adjustment cam is located at the point where the front of the LCA attaches to the cradle. If you don't see a cam with a bolt through it at that location then it is possible somebody previously installed some fixed camber plates in place of the cam. As for the number of spacers at the top do you have bolts holding the UCAs in place or do you have studs with nuts?
Bill
Bill
