C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] New setup A&A supercharger
Old 11-05-2014, 10:28 PM
Cidz06
Cidz06's Avatar
Default New setup A&A supercharger
Well a couple months ago I did heads,cam and made 586 rwhp. I was happy with it, but started to crave more power later on...So I decided to get an A&A supercharger kit T-trim 4 inch pulley from Andy. I sold the FAST intake and NW throttle body and put back the stock intake and throttle body on. I took the 2 hour drive to Victoria and have Patrick G. tune the car on a mustang dyno Monday night. I only took a pic of the the numbers before the meth. The last run with meth was on setting 2, didn't think I need it that much cause my IAT's was already low, and it was pretty late at night I was tired and didn't ask him for the numbers , just waiting now for him to email me the final numbers and graph. Car runs real good and happy with the numbers. Awesome tune from Patrick G.
All installation work done by me
Previous Mods:
VR/WCCH stage 2 heads unmilled
VR Ported FAST 102 intake
FAST billet rails
Stock throttle body
Halltech Super Bee MF105S
Tick Performance Ls7 Polluter cam
Katech C5R Timing Chain
Comp pushrods
160-degree thermostat
LG 1 7/8 headers
Off-road X-pipe
Corsa cat-back exhaust
586rwhp 529rwtq
New/same mods:
Stock intake
Stock TB
Stock clutch
Ls7 Blower cam from PCM of NC
RSD 3 inch cut down radiator
A&A Vortech T-Trim 4 inch pulley
80lb injectors
Boost a pump
Racetronix fuel pump harness
Aero force fuel pressure sensor
Dashlogic
MightyMouse catch can/ breather
MightyMouse Z06 bracket
Alky control kit dual nozzles/VP M1
ZR1 map sensor
Relocate IAT sensor into intake
Comp pushrods
LG 1 7/8 headers
Off-road X-pipe
@7psi
Old 11-05-2014, 11:32 PM
DaOtherOne
DaOtherOne's Avatar
Looks great .. killer numbers
Old 11-05-2014, 11:38 PM
Rupert pupkin
Rupert pupkin's Avatar
NICE!! Did I see 750? Stock bottom end too? Specs on the cam?
Old 11-06-2014, 08:54 AM
Cidz06
Cidz06's Avatar
Yes stock bottom, 222/246 .63x/.65x 115 +2
Old 11-06-2014, 09:45 PM
EnginerdVT
EnginerdVT's Avatar
I'm considering doing the same to mine, but really worried about the stock bottom end on that type of setup...
Old 11-06-2014, 10:33 PM
Brandon619
Support Corvetteforum!
Brandon619's Avatar
Great numbers that bottom with last with this setup just be mindful when you push it hard and read your spark plugs.
Old 11-06-2014, 11:07 PM
telly444
telly444's Avatar
great set up, awesome numbers... 7 psi on stock LS7 bottom is a bit concerning. lol
Old 11-08-2014, 01:02 PM
LemansbluebyU
LemansbluebyU's Avatar
St. Jude Donor '12, '15
I did those similar mods in reverse order and am at the same numbers, I can tell you this, if you plan on running the car at the strip don't put any kind of traction on the car if your still running the stock clutch........it won't last, not really gonna last either way but traction will kill it. I got 2 passes on my NT05's (not DR) the first time out and 3 weeks following I went back to the track when I got some NT05R's I couldn't even make a full pass without slip, even let the smoke out half way down the track on the second pass....... Time for some upgrades down below!! Have fun with her, she's a whole new animal now
Old 11-08-2014, 01:03 PM
LemansbluebyU
7 psi on the bottom end isn't that concerning.....It's the close to 750 rwhp that is way more of a concern
Old 11-08-2014, 05:12 PM
Cidz06
Cidz06's Avatar
This thing is a beast,I've been on it a couple of times. So I guess I'm already pushing the limits of the stock short block. I've been thinking about getting a smaller pulley and going for 800.
Old 11-08-2014, 07:06 PM
Q427
Q427's Avatar
Thats awesome !
Old 11-13-2014, 12:35 AM
Cidz06
Cidz06's Avatar
New numbers with meth on low setting for now
Old 11-13-2014, 12:48 PM
Chris Bert
Chris Bert's Avatar
So a blown ls3 holds together better than a blown ls7? Guessing cause thicker walls and all that junk?
Old 11-15-2014, 12:38 AM
Twistedpixels
Twistedpixels's Avatar
Yes and yes. Ls7's are not good blower motors at all. Thin walls and poor heat transfer then the short piston skirts. The block I would run is the Ls2 block sleeved to do a 427ci still. The awesome way to go is the DART blocks but to stay aluminum it is crazy expensive so you have to go with the iron block to not spend a fortune.
Old 11-17-2014, 12:02 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Yeah we have heard that all the while the boosted 427 works great and many many running around with more than 600 rwhp and
they fly so if you don't know and are new here and to the 427
live and learn.
Old 11-20-2014, 08:29 PM
MIGHTYM0USE
MIGHTYM0USE's Avatar
looks great! good job.
Old 11-22-2014, 01:29 PM
garye
garye's Avatar
St. Jude Donor '12-'13-'14-'15, '21
so, should you or should you not supercharge an lS7? I was considering it but I don’t want to blow up my motor. It might be better to just do cam and headers and a tune and see what HP I get out of that. I have a 2013 427 vette.
To New setup A&A supercharger
Quick Reply: [Z06] New setup A&A supercharger
