[Z06] KNS Brakes - Carbotech Corvette Coupon Code!! - See Inside For Details
Supporting Vendor
At KNS we have your Carbotech pads in stock and we now have an active coupon code that you can use to save $$ when you order online.
The code is CF5OFF.
www.knsbrakes.com - enter code at checkout
Or you can call us - 919-420-0021
Please use this code for Carbotech pads only. It might work for other items but please inquire before using.
Carbotech has several compounds from street to race.
Carbotech™ 1521™ [THIS COMPOUND IS BEST FOR STREET CARS FOR LESS DUST AND NO NOISE]
The Carbotech™ 1521™ is a high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™ [THIS COMPOUND IS BEST FOR AGGRESSIVE STREET/DRAG USE AND VERY LIGHT TRACK USE. EXPECT FAIRLY HEAVY DUST AND SOME NOISE.]
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
Carbotech™ XP8™ [THIS COMPOUND IS BEST FOR BEGINNING TRACK USE WITH STREET TIRES AND MODERATE TRACK DRIVING. SOME USERS DO LEAVE IT ON FOR INTERMITTENT STREET USE BUT EXPECT DUST AND NOISE.]
A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™ [THIS COMPOUND IS BEST FOR INTERMEDIATE TRACK USE WITH STREET TIRES AND HARDER TRACK DRIVING.]
When Carbotech™ unleashed the XP10™ to the general public it immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1475°F (801°C). XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™ [THIS COMPOUND IS FOR HARDER TRACK USE WITH MORE AGGRESSIVE TIRES AND DRIVING]
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 1850°F+ (121°C to 1010°C+). The XP12™ has that excellent Carbotech™ release and modulation that has made all other Carbotech™ compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP20™[XP20 and XP24 COMPOUNDS ARE A SIGNIFICANT JUMP IN FRICTION FROM XP12 AND ARE SUGGESTED FOR MORE EXTREME CONDITIONS USING RACE TIRES.]
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, linear torque curve and excellent fade resistance the XP20™ is another major step in progression of the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP24™ [XP20 and XP24 COMPOUNDS ARE A SIGNIFICANT JUMP IN FRICTION FROM XP12 AND ARE SUGGESTED FOR MORE EXTREME CONDITIONS USING RACE TIRES. XP24’S ARE SUGGESTED TO RUN AT 1000 DEG OR UP AND PREBEDDING IS HIGHLY RECOMMENDED.]
XP24™ is the pinnacle compound of the extremely successful XP™ Series of compounds engineered by Carbotech™. This compound is based on the same fundamentals that exist in all other Carbotech™ formulations. XP24™ has even more initial bite, more overall bite, and more torque along with the most linear torque curve we have ever offered. The thermal characteristics are of the highest Carbotech™ offers along with one of the highest coefficient of friction ratings offered by anyone in the braking industry. This compound is the longest wearing compound Carbotech™ offers as it was originally engineered for endurance applications at the highest pro racing levels. This revolutionary new compound has been extremely successful with open wheel, closed wheel, sprint and endurance applications. XP24™ has a temperature range of 400°F to 2000°F+ (204°C to 1093°C+). Carbotech™ XP24™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise along with the necessary heat required to work properly.
The best deals on Corvette brakes are always at KNS Brakes.
-Ken
The code is CF5OFF.
-Ken
Supporting Vendor
Performance depends on which OEM you refer to. Looks like you have a C6Z06? You'll lose a bit of initial bite compared to those.
-Ken
